A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
retrofit servotronic to a4b8
Old 12-13-2012, 02:52 PM
pulsar1230's Avatar
Default retrofit servotronic to a4b8
hi i am trying to retrofit servotronic steering to my a4 b8 avant auto 2009 2.0 tdi i have the correct rack out of an 2010 s line a4 avant but need the wiring diagram or instructions to wire from the socket on the rack to the ecu or were ever i realise i will have to recode to activate as well, any help would be greatly appreciated.
Old 12-14-2012, 07:01 AM
Jatmobil's Avatar
Try this for starters! Hoping you have access to a coding tool such as vag com. I am also hoping that this is not a dead end as this repair manual link below says that the steering wheel control unit has to be coded online using SVM (software version management)
notice: The link below will take you to menus that I have openend up to head you in the right direction.. play around with the menus to see which choice leads to you what you are looking for!
http://elsaweb.spaghetticoder.org/na...1776/10648709/
Old 12-14-2012, 09:52 AM
pulsar1230's Avatar
hi jatmobil thanks for your reply it has been a great help, i was under the impression all i needed was the correct rack and two wires running to the euc but looking at the repair manual link it looks like i will also need a control unit J792 and the ACTUATOR which is built into the lower steering column which is the electric motor which helps turn the wheels thus making the steering lighter/heaver depending on your speed,i am getting all the parts from the breakers yard so can anyone confirm exactly all the parts i would need to take off the doner car.
04-17-2009 04:16 AM
fidget
11-03-2008 03:12 AM
JettaManDan
08-08-2008 06:52 AM
SCd_Walter
06-21-2004 02:41 PM
etmag
02-11-2004 09:07 AM
Quick Reply: retrofit servotronic to a4b8
