P0420 issue
P0420 issue
I was hoping someone could help me with my 2009 Audi A4 2.0T with 135k, no mods, totally stock
About 3 months ago code 420 popped up ( prior to this engine mounts were replaced)
The local mechanic stated that the cat needed to be replaced and that the rear O2 sensor depending on its condition would need to be replaced.
Cat was replaced.
Picked up the car and 3 days later code appeared. Same code
mechanic replaced the rear sensor with Bosch OEM, front sensor
Picked up car and 3 days later same code
Identified that flow meter was bad, replaced
Picked up car 3 days later same code
Identified that the fuel was below recommened flow, replaced the filter. Flow back to normal
Picked up car 3 days later engine light came up. then disappeared for 2 days , then engine light came up. Took it back and its the same code 420
Mechanic is not sure what is next. Stated the all his tests are coming back fine, flow,exhaust etc.
Anyone have an idea of what to do next? not only replace but diagnostic testing?
Could I need to flash the ecu?
frustrated.. I miss my audi
Cat was replaced.
Cat was replaced.
Cat was replaced.
( had a clogged PCV valve in my old Xterra, kept blowing intake valve covers..)
gerisilo
10-22-2010 04:56 AM
MDM_A4 (Michael)
Florida Discussion
06-19-2008 10:02 AM
