Part 2 Oil Consumption Test FAIL.
Part 1 was done 4k+ miles ago, Add Oil Light went ON, in for Part 2=FAIL, new engine stuff being done as I write to solve the problem.
'11 A4 P+, TIP, 24,463 mi, bone stock.
It is really depressing to read about this problem with 2.0 engines that are not that old. I remember when the 2.0 first came out replacing the 1.8 and it was supposed to be one of the greatest engines ever built. Instead, it has been nothing but problems with the oil issue, coils and faulty fuel injectors. When the engine is running properly, it is fantastic, but this should never have happened on a luxury line of vehicles like Audi.
You are spot on when you say "this should never have happened on a luxury line of vehicles like Audi.".
Mine seems to be deteriorating a bit - not sure if it will make 5k on a quart since the last time I added oil. It did 3k per quart before part 1 and was pushing 6k after that. I have 42k on the odometer.
Yes that's correct. Honestly I'm as surprised as you. I was advised that Part 2 is a 2 hour procedure so the final determination could be more than just oil consumption. Speculating, maybe there's a 'field test' for oil contaminants or presence of any metallic substances.
If it fails along the way with additional consumption and part 2 is needed are you financially responsible? I'd raise a flag to Audi over this.
We had all of part 1 & 2 done with a loaner in both stages at no cost to us.
I don't get it.
Your dealer did part 1 and you paid for some of the work? Why?
I don't get it.
I don't get it.
Do I read you correctly that you went 4k+ miles on a quart of oil and you got approved for the piston and rings job? Last time I heard they would not do that for more than 2k per quart.
