please drain oil
please drain oil
Hello,
just got an oil change at my mechanic's and when i checked on the oil level and i also wanted to check and see if they had changed the service intervals there is a message on the screen that says "please drain oil" is that something i can reset myself? or do i have to go back to my mechanic to reset it?
+1. You've got to be grossly over-filled to get that warning.
Dreamer, has the "mechanic" ever worked on an Audi before? Could he have forgotten to drain the old oil before re-filling with the 5 qts
Yes, he has been my mechanic for a long time and even before i got the audi i asked him if he serviced Audis and he said yes. Maybe i will give him a call and discuss to see exactly what he did.....i have heard that audi dealers have done that same thing before, so at least i know it is not uncommon.
I just talked to my mechanic, and he said he drained the old and put 5 quarts in. He said to bring it in on monday and he will use a dipstick to measure and see why i am getting the message.
Don't know if it matters but the manual says the car takes 4.9 quarts. The filter retains some oil as well. Was it changed at the same time?
The extra .1 of a qt. will not set this message. You would need more then 1/2 a qt for the message to come up. It almost sounds like he drained the oil and did not change the filter and then added 5 qts. By the way 5 qts with a filter change is OK
buy a dipstick for yourself.
Hello,
