Quiescent current Audi A4 B8 1.8 TFSI - AudiWorld Forums
A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5-present
Old 03-31-2014, 02:05 AM   #1
Default Quiescent current Audi A4 B8 1.8 TFSI
Hi.
Two days ago in my car has gone the battery. I'm a little surprised, because the car is from the year 2011.
After buying a new battery I checked quiescent current of the vehicle.
On the start, the value of the current was about 4 A, and after about 10 minutes, fell to 0.41 A.
Whether the current 0 .41 A is normal?
It's already time to look for a device that "steals" power, and if so, where to start ?
Cheers Andrew
andrzej19 is offline   Reply With Quote
Old 03-31-2014, 11:13 AM   #2
Many modules in the car consume current to listen to the CANbus. There comes a point when this is no longer productive as the bus itself has gone quiet.
410 mA is too much. At rest the car should draw 50 to 100 mA, depending on individual devices and temperature.
The first place to look is the obvious culprits, a glove box or trunk lamp.
It might be cheaper to simply ask a dealer to chase the trouble because they have the tools to do that without causing more damage.
Moviela is offline   Reply With Quote
Old 04-01-2014, 02:42 AM   #3
Thank you for Your reply.
However, I wonder that, according to various opinion - older cars (without CAN) and later (with CAN) have the same power consumption. (50 mA - 100 mA). I think that these values ​​should be different.
Am I right?
Old 04-02-2014, 11:39 PM   #4
Older cars had electronics that drew that amount, mostly engine controls and entertainment systems.
Modern cars with CAN (controller area network) turn the transceiver on and off. When awake LED's in each device draw about 20 mA. When all are asleep they each draw micro amps while listening for a signal. That is why old and new cars draw about the same amount when switched off.
Some modules develop a problem that does not allow sleep, and just like noisy neighbors, they keep everyone else "awake."
You can disconnect different modules to find out who is the bad actor. Problem is they are located all over the car. Some require considerable time to expose using this technique, whereas a dealer can use his online tools to point to the bad boy.
Old 04-04-2014, 02:20 AM   #5
Thank you for your help - tomorrow I start searching for the cause of the problem.
Old 04-06-2014, 01:06 AM   #6
Problem solved - it is to maintain the navigation system is drawing too much current. After the repair, the current drawn by the vehicle is 40 mA.
Thank you for your help.
Old 04-06-2014, 01:26 AM   #7
How did you manage and what method did you use to isolate the problem?
audi8k is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
ChipWerke module for S4 tonalvoltage S4 (B8 Platform) Discussion 2 10-22-2015 08:11 PM
2016 Audi TT-RS spied testing at Nurburgring Video trevakaed TT (Mk3) Discussion 0 09-27-2015 03:16 PM
2.0 TFSI power loss Tom10 Audi A3 / S3 / RS3 7 09-16-2015 12:17 PM
Video Review of the 2016 Audi A7 1.8 TFSI S Line Alaatin61 A7 4 09-14-2015 03:04 AM
Tags
18, a4, audi, b8, feedback
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
