A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Old 08-22-2016, 03:02 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A4 (B7) Interior Guides
Print Wikipost
Trouble removing the key fob from the ignition slot
Old 09-26-2008, 07:37 PM
audi40's Avatar
Default Trouble removing the key fob from the ignition slot
Not sure if I'm doing something wrong, but more than half the time after I shut the engine down, I can't remove the key fob from the ignition slot...have to restart the engine, shut it down and then remove it (sometimes takes 2-3 tries). Anyone else have this problem?
Old 09-26-2008, 07:42 PM
Mobilehavoc's Avatar
Never had a problem yet. When the car is off, it should just pull out every time.
Old 09-26-2008, 07:46 PM
Member
Big D's Avatar
Default I have.
In 3 out of the 4 cars I have test driven it has been an issue. Just make sure that you dont have much on the keychain. if there is any weight that pulls it or lifts the fob up or down, it will not return the key to you. I had no idea it was so sensitive, but with the problems I had, I knew there had to be a reason for it.
Old 09-26-2008, 07:55 PM
audi40's Avatar
Default Re: I have.
I do have 10 or so keys on my key ring, including a key fob for my wife's Pilot...I'll see what happens if I remove the other keys or maybe just try to lift the other keys to reduce the weight on the Audi fob before shutting the engine down. Thanks.
Old 09-26-2008, 08:06 PM
Member
Big D's Avatar
No problemo.
Old 09-26-2008, 11:08 PM
New Member
Ullfy's Avatar
Default Thats strange I am having this aswell.
I have no keys hanging. Guess that its happening 30% of the time. Anyone with ideas on this, let me know. I never gave it much thought before and thought i was doing something wrong ??
Old 09-27-2008, 03:56 AM
snagitseven's Avatar
Default Same here although now that my defective on/off switch was replaced..
I don't using the slot any more due to the advanced key feature.
I had some other keys including my heavy allroad key on the ring so that may have been the cause.
Old 09-27-2008, 06:47 AM
rraffel's Avatar
Default I did at the beginning, but not anymore
I had this problem the first 3 or 4 times I shut the car. Trick is not to pull the key out too quickly or too soon after shutting the car. Wait about 2 seconds after pushing it in and it will slide out easy. I thought it might have been the weight from my other keys (have about 10), but since I've been waiting those 2 seconds, I haven't had a problem.
Old 09-27-2008, 06:48 AM
Explains it....I always waited a few seconds naturally before pulling the key out.
Old 09-27-2008, 09:11 AM
New Member
STAudiTT's Avatar
Default Solution......
I was having this problem as well, had to keep restarting car and hoping it would release. It was fixed when I realized that when I pushed the key to turn the car off, DO NOT PULL on the key. Just push it, the car turns off and you will hear a slight click, then you can pull the key out. You almost have to wait 2 seconds for it to release. I have not had it get stuck again, after realizing this. Hope this helps.
Quick Reply: Trouble removing the key fob from the ignition slot
