VAG Scan = Adaptation Overboost?
My car was involved in a head on collision (not that bad) but the driver Airbag deployed. Before i started ordering things i decided to do a scan on my 2009 Audi A4 Quattro 2.0 T and this popped up.
Address 03: ABS Brakes Labels: 8K0-907-379.clb
Control Module Part Number: 8K0 907 379 AB HW: 8K0 907 379 AB
Component and/or Version: ESP8 quattro H04 0060
Software Coding: 150500
Work Shop Code: WSC 02399 823 56573
VCID: 79F92B19F03EFBA41EAB29
1 Fault Found:
00473 - Control Module for Elect. Park/Hand Brake (J540) I think this has to do with the crash sensor
013 -- Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 245
Mileage: 151441 km
Time Indication: 0
Date: 2015.01.16
Time: 23:11:07
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0013
Hex Value: 0x0293
Hex Value: 0x00FF
Address 09: Cent. Elect. Labels: 8K0-907-063.clb
Control Module Part Number: 8K0 907 063 C HW: 8K0 907 063 C
Component and/or Version: BCM1 1.0 H22 0253
Software Coding: 690000B1063C00010000080000007F5F0F1452080000000100 0000
VCID: 2F6DD5417EFAE514F0CF17
03201 - Adaptation Overboost Stumped
012 -- Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 151441 km
Time Indication: 0
Date: 2015.01.16
Time: 23:39:00
Address 15: Airbags Labels: 8K0-959-655.clb
Control Module Part Number: 8K0 959 655 C HW: 8K0 959 655 C
Component and/or Version: AirbagVW-AU10 H26 0410
Software Coding: 303836354230303030304A55304C384B3053
Work Shop Code: WSC 02145 785 00200
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007 (AU48)
VCID: 3D71FF09AC9607847273BD
Fault Codes have been Erased
1 Fault Found:
9443859 - Driver's Front Airbag Crash Sensor This is because of the deployed airbag from the crash
B101A 15 [137] -- Open or Short to Plus
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 151441 km
Date: 2015.01.16
Time: 23:17:29
Address 53: Parking Brake Labels: 8K0-907-801-V1.clb
Control Module Part Number: 8K0 907 801 E HW: 8K0 907 801 E
Component and/or Version: EPB Audi B8 H05 0060
Software Coding:
Work Shop Code: WSC 00000 000 00000
VCID: 3169D33968CEF3E4E6FB01
1 Fault Found:
01321 - Control Module for Airbags (J234) This is because of the crash sensor
013 -- Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 245
Mileage: 151441 km
Time Indication: 0
Date: 2015.01.16
Time: 23:23:41
Freeze Frame:
Voltage: 11.90 V
Count: 80
Speed: 0.0 km/h
Hex Value: 0x0273
Hex Value: 0x0001
Hex Value: 0x1010
I searched for info and kind of get the idea of what is going on regarding the DTC errors, but i'm stumped with the Adaptation Overboost code..any ideas?
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 245
Mileage: 151441 km
Time Indication: 0
Date: 2015.01.16
Time: 23:11:07
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0013
Hex Value: 0x0293
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 151441 km
Time Indication: 0
Date: 2015.01.16
Time: 23:39:00
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 151441 km
Date: 2015.01.16
Time: 23:17:29
Software Coding:
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 245
Mileage: 151441 km
Time Indication: 0
Date: 2015.01.16
Time: 23:23:41
Freeze Frame:
Voltage: 11.90 V
Count: 80
Speed: 0.0 km/h
Hex Value: 0x0273
Hex Value: 0x0001
Hex Value: 0x1010
