What's the coolest coding setting on a B8?
#41
What about (re-)programming our cars to accept and use the newer facelift (b8.5) lights (which have brake lights and turn signals in both the inner and outer lenses, not just the outer)? This is a popular modification and it would be great to have a single checkbox toggle to change modes in one swift action.
Or even more fun: programming North American cars to accept Rest of World (RoW) or "Euro" lights (which have discrete brake lights and turn signal indicators that are not joined like North American lights).
#42
I'm trying to decide whether to get an adapter and play around with Carista. Is the list in dap1974's post earlier a complete list of the tweaks?
If not, is there a full list somewhere that I can check out?
#43
Complete list on my car;
Doors / Windows / Remote:
Auto-lock doors when moving
*YES* / NO
Auto-unlock doors when key is taken out of ignition
*YES* / NO
Auto-lock trunk when moving
*YES* / NO
Beep when alarm is armed
*YES* / NO
Unlock doors via remote
*DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND* / ALL DOORS ON 1ST PRESS
Unlock doors via smart key (door handle button)
Enable settings for opening/closing windows and sunroof
*YES* / NO
Open/close windows and sunroof via long-press on remote
*YES* / NO
Close windows via long-press on remote
*YES* / NO
Open windows via long-press on remote
*YES* / NO
Close sunroof via long-press on remote
*YES* / NO
Open sunroof via long-press on remote
YES / *NO*
Sunroof action when opening via remote
SLIDE / *TILT*
Open/close only driver's window via remote or key
YES / *NO*
Open/close windows and sunroof via smart key
*YES* / NO
Close windows via smart key
*YES* / NO
Close sunroof via smart key
*YES* / NO
Open/close windows and sunroof by holding key in door lock
*YES* / NO
Open windows by holding key in door lock
*YES* / NO
Open sunroof by holding key in door lock
*YES* / NO
Close windows by holding key in door lock
*YES* / NO
Close sunroof by holding key in door lock
*YES* / NO
Close convertible roof via long-press on remote
*YES* / NO
Close convertible roof by holding key in door lock
*YES* / NO
Close convertible roof via smart key
*YES* / NO
Open convertible roof via long-press on remote
*YES* / NO
Open convertible roof by holding key in door lock
*YES* / NO
Blink turn signals when done closing windows via remote
*YES* / NO
Enable remote control when vehicle is running and in gear
YES / *NO*
Instruments / Display / Dings:
Gauge needle sweep at startup
*YES* / NO
Gauge needles lit even when headlights are off
*YES* / NO
Gauge scales lit even when headlights are off
*YES* / NO
Seat belt warning
DISABLED / US/CANADA STYLE / EURO STYLE 1 / EURO STYLE 2 / *EURO STYLE 3*
Lights:
Allow configuring daytime running lights via dash display
YES / *NO*
Use front LED lights as daytime running lights
*YES* / NO
Use fog lights as daytime running lights
YES / *NO*
Use high beams as daytime running lights
YES / *NO*
Use tail lights as daytime running lights
YES / *NO*
Use side marker lights as daytime running lights
YES / *NO*
Use low beams as daytime running lights
YES / *NO*
Dim daytime running lights when ignition and parking lights are both on
*YES* / NO
Turn off daytime running lights ("wink") when turn signal is on
*YES* / NO
Coming-home lights
*ENABLED* / DISABLED
Leaving-home lights
Use fog lights as coming-home lights
*YES* / NO
Use low beams as coming-home lights
YES / *NO*
Turn off front fog lights when high beams are on
YES / *NO*
Turn off rear fog lights when high beams are on
YES / *NO*
Lower headlights for traveling to RHD/LHD country
YES / *NO*
Flash brake lights in emergency stopping
*YES* / NO
Flash hazard lights in emergency stopping
YES / *NO*
Turn on side marker lights with headlights (US models only)
*YES* / NO
"Euro" parking lights when ignition off, turn signal on
YES / *NO*
Other:
Lower passenger-side mirror when in reverse gear (may need memory seats)
*YES* / NO
Remember position when lowering passenger-side mirror in reverse gear
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
YES / *NO*
SLIDE / *TILT*
YES / *NO*
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
YES / *NO*
*YES* / NO
*YES* / NO
*YES* / NO
Seat belt warning
Lights:
YES / *NO*
*YES* / NO
YES / *NO*
YES / *NO*
YES / *NO*
YES / *NO*
YES / *NO*
*YES* / NO
*YES* / NO
Coming-home lights
Leaving-home lights
*YES* / NO
YES / *NO*
YES / *NO*
YES / *NO*
YES / *NO*
*YES* / NO
YES / *NO*
*YES* / NO
YES / *NO*
Other:
*YES* / NO
*YES* / NO
#44
no. i have 15 a4, and the mirror tilts down in manual trans reverse, But, only if the mirror adjustment **** is set to right side, and you have programmed the mirror turn down feature , ahead of time.
#45
Fox Fader - Thank you! There are a few things on your list that stood out:
I had no idea A4s could do this. I have mixed feelings about this feature in other cars. When I first saw it (in an '06 IS250), I thought it was cool and spaceship-like. But now that everyone seems to be doing it (including Buick), it seems silly. Do you see value to it?
Looks like you chose "no" for this feature and that you have PP and thus the xenon lights. Do the additional fog lights make a meaningful difference with high beams?
Have you seen this in action? I'm wondering whether they flash fast (e.g., like a strobe light) or whether it's more like the hazard lights. It seems like slow flashes could be more dangerous than beneficial.
#47
#48
[QUOTE=Det. Mickylaren;24629673]Fox Fader - Thank you! There are a few things on your list that stood out:
I think it looks cool.
Doesn't make a big difference, but it drove me crazy when I turned the high beams on and frog lights went off
#49
Dolphin, if you don't like the gauge weep, then select no.
As far as the fogs on with hi beams....that's just how I like to have em. Just me. I rarely use the highs anyway.
#50
carista app not working
I have a 2014 a4 and the phone finds the obd reader. but when it starts searching for customizations, the percent never moves from 0%. and then eventually after like 5-10 mins it says it doesn't work. whats the dealio? any suggestions help. thanks
