2005 A4 3.0 Coolant Leak
Hi,
My mechanic said coolant leak coming from seals below engine would cost $1300 w/parts and labor. Mostly labor. Does that sound about right?
Should I go to a radiator shop instead? Any recommendations in NY/NJ/CT area?
Thanks
Thanks
Jason
Sounds like they are referring to the part below that is leaking.
Its located on the back of the engine so that could be very time consuming to replace, hence the larger labor charge.
That is the coolant supply pipe for the cylinder heads.
Jason
Jason
heateris
09-09-2008 08:34 AM
