A4 Cabriolet (B6 Platform) Discussion Discussion forum for the B6 Audi A4 Cabriolet
Convertible top
Old 03-20-2017, 01:22 PM
Kendra's Avatar
Default Convertible top
Push the button top goes down with know problem, push button trunk pops open about 2 inches and will not move can only open truck manually
Old 03-20-2017, 03:10 PM
Firefighter's Avatar
I hope not, but it could be the hydraulic system that operates the top and/or the button itself that activates the top .
Sometimes the top has to be reset, meaning it is "out of cycle" for some reason.
This process involves manually lowering the top and manually bringing it back up and locking it in place. Sometimes (I hope so) that is all that is required.
Go on You Tube and check under something like Audi top reset or something like that.
Good Luck.
Old 03-26-2017, 05:50 PM
ltooz_a6_a8_q7's Avatar
http://www.dognmonkey.com/audi/fix-g...cabriolet.html
Old 04-19-2017, 06:29 PM
Sissing's Avatar
Mine gives me a problem opening if it hasn't been opened for a while and its nose is point uphill. It requires me to manually open, some times if everything is exactly aligned where the load is off it will finish opening, but only if level or the nose is down hill. Fingers crossed, it seems to work if the nose is level or facing down hill.
Old 01-25-2018, 06:46 PM
RoMan709's Avatar
Default A4 Cabriolet Top Manual Reset Video
Well you know, if it happens once "it's a bug..." but if it happens more than once "it's a feature"... In this case it is true...there is a feature that protects the top from damaging itself if the top is at a severe uphill angle. It is the reason why the following video was done...
Squalo
Audi A3 / S3 / RS 3 MKII
9
08-25-2022 01:19 AM
rbuckstar
11
12-26-2007 05:31 PM
FSI Power
A4 (B7 Platform) Discussion
11-29-2007 08:46 AM
omen62
Audi 100 / A6 (C4 Platform)
02-08-2005 07:49 PM
qwerty
07-31-2002 12:40 PM
Quick Reply: Convertible top
