19" or 20" OE Rims?
#11
If I recall Goldilocks correctly the 19s are the Mama bear variant.........unless of course roads where you live are total sh*t. Stick with your 19s assuming your roads are less than excellent. You will be glad you didn't switch to 20s.
Nakedhoof totally correct regarding ride compliance. Sportstick's car is on 18s and rides more compliant than mine on 19s w/sport suspension.
#12
I need some advice on one last issue - I recently bought some 19" winter tires from TireRack as I had a gift certificate that I needed to use. As I presently have only one set of wheels, I had originally planned on just mounting/unmounting them every early winter/early spring - switching them out with the all seasons that came with my vehicle when I bought it (in 12/15). However, I just read that it's not good for either the rims or the tires to be doing this twice a year, and so for that reason was thinking of buying a new set of wheels, and having one set dedicated for summer/or all seasons, and the other for the winters. Is this true that it's not a good idea to be mounting/unmounting two different sets of tires on the same rims that frequently? I was going to have the dealer's service dept do it each time. Is there really that much of an increased risk that the rims or tires will be damaged in the process? Just not sure if I should be dropping a whole lot on a new set of wheels if it's not necessary..
#13
1. less expensive in the long run - mounting and balancing twice a year is not free
2. reduces the chance of damage from salt, potholes and curbs
3. I can install a set in the drive way in less time than a round trip to the dealer. Any repair shop and switch your tires and sometimes offer it as a service during a oil change
4. any time you mount a tire, there is a chance of bead or rim damage
5. you can sell the set if they don't fit your next car
I usually have dark winter wheels so the dirt is not as obvious.
#14
+1 on all the above and it now gives you the option of going with 18 inch wheels!!!
Put mine on yesterday. Here's a pic.
#16
- narrower tire sizes will be easier to find in 18" and you want narrow for winter.
- not good to be driving around on 19" wheels/low aspect ratio tires just as potholes are being born.
The tirerack.com wheels are not that costly, and if you choose some low pressure cast wheels, they will be of better quality than the gravity cast and often lighter weight. Check the specs on their website.
#17
Moonlightblue mine were $1495 delivered and did not require centering rings. As a mechanical designer by trade that was important too me. Less parts IS better!
#18
I chose the 17" wheels from Tire Rack. Graphite Rial Kodiak wheels - low pressure cast - 23 pounds - 20 lug bolts included. Total price shipped was $1000 plus change with the $130 in Goodyear rebates.
I bought them a week before buying the car since it was November and the car was on summer tires. I thought they looked bland so I added the red wheel rim tape.
#19
#20
