2012 A6 Coolant Temperature Too High! - AudiWorld Forums
A6 (C7 Platform) Discussion Discussion forum for the C7 Audi A6 produced from 2011
Old 05-13-2014, 04:41 PM   #1
Default 2012 A6 Coolant Temperature Too High!
Hi
I have a 2012 A6 Prestige with 62k on it. After about 20 minutes of driving or less depending on outside temp and ac usage, the car over heats and I receive "coolant temperature too high" as a message. I of course turn the car off and let it sit and cool down. I took the car to get serviced and was told there was an air pocket in the coolant system which they say was low. I drove the car for another 20 minutes or less and received the same issue. Has anyone ever had this issue before? I don't see any leaks or signs of water, the engine doesn't even seem to be really hot. I'm wondering if it may be a sensor error, or is it really that the water pump and thermostat need changed. Any help would be greatly appreciated. Thanks so much....
casmith is offline   Reply With Quote
Old 05-13-2014, 05:00 PM   #2
Lots of thermostat failures. Some water pump failures as well.
mjfloyd1 is offline   Reply With Quote
Old 05-13-2014, 05:12 PM   #3
jcman's Avatar
Quote:
Originally Posted by casmith View Post
Hi
This is the C5 forum have you tried the C6 forums?, although I do agree that CTS sensors do fail.
jcman is offline   Reply With Quote
Old 05-13-2014, 05:21 PM   #4
tenspeed's Avatar
Quote:
The 2012 A6 is a C7 platform. There have been several reported thermostat failures with the 3.0L TFSI engine. Some shops replace the water pump too.
http://forums.audiworld.com/showthread.php?t=2858298
tenspeed is online now   Reply With Quote
Old 05-13-2014, 05:59 PM   #5
Quote:
Thank you so much, I appreciate it.
Old 05-13-2014, 06:01 PM   #6
Thank you so much, I am VERY new to this. I'm just desperate for help. I appreciate your assistance.
Old 05-14-2014, 04:51 PM   #7
jcman's Avatar
Very informative indeed, but this is the C5 forum.
Old 05-15-2014, 03:55 AM   #8
SloopJohnB@mac.com's Avatar
Agreed. It's more likely a thermostat failed closed. If I were king all thermostats would fail open…at least you could drive the car. Unsane audi engineers.
SloopJohnB@mac.com is offline   Reply With Quote
Old 05-15-2014, 03:56 AM   #9
Probably end up pulling the w/p anyway to get to the thermostat..investigate w/p at that time.
Old 05-16-2014, 09:44 AM   #10
Make sure the secondary coolant fan is working, too. Mine did this only when I turned the A/C on, turns out the electric fan had croaked.
Zaphodb17 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
2012 Audi a7 retrofit to 2016 facelifted. spit03 A7 6 01-31-2017 03:03 PM
Current gen S5 vs. 2017/18 S5 Hova26 Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 6 09-29-2015 12:12 PM
APR Tune Net Nannies stay away dougpaper A6 (C7 Platform) Discussion 9 09-28-2015 01:47 PM
Deciding between a Golf R or an S3- Need some opinions Captain Rossness Audi A3 / S3 /RS 3 MKII 26 09-24-2015 05:34 AM
Considering C7 3.0T: Questions regarding M.Y. changes, reliability, etc. wirewick A6 (C7 Platform) Discussion 11 09-20-2015 01:29 AM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
