2016 A6 3.0T Wheels Suggestions???
#12
I have 19x9.5 Niche from 19x8 oem on my 2012.
I was unsure of 19" and 9.5 do I go with 20s but I do love the size.
I used the same stock size tire 255/40 and it is perfect. Gave a little more stretch and it is about a .2" drop on the car. So the rim fits the wheel well nice, no more gap everyone thinks it is dropped with aftermarket 20s.
and there is no ride/noise impact either
what was the offset on this? 42mm?
#14
got it, now his post makes more sense.
EDIT: actually jjcuff1's tire size is 255/40 NOT 245/40
do you always go with the recommended tire size from the wheel manufacturer? it makes sense, because they should know the tire size that works best with their wheels?
#15
No, you go with the recommended tire size per the auto manufacturer, but you have a bit of latitude with the tire width as long as the overall tire diameter is within 1-2% of the OEM tire diameter. Every tire size has a wheel width range which is acceptable and you can choose the wheel width within that range. But here's the good part. If TR says that a wheel will fit your car, it will, as they test fit the wheels.
#16
Can anyone let me know if I should go with 19x8.5 or 19x9.5 wheels?
What would the lookbe like between those two sizes on the A6?
Looking to place order today.
Thanks
Thanks
#17
According to the site below, the standard rim size for 255/40/19 tires is 19 x 9.5. Is taht accurate?
Wheel/Rim Size Calculator - Shows acceptable rim width range for the tyre size
#18
Hi all, I am like to get some 19" wheels for my 2016 A6 3.0T Premium Plus and would really love some suggestions.
What brands should I look at for quality without putting a hole in my wallet? VMR, Hartmann, Avant Garde, BBS, TSW, etc.?
What style, finish, material should I look for?
What size should I look for? 19x8 or 19x8.5, etc.
I really prefer a 19" set that is a perfect fit for my 2016 A6.
As for tires, I am all set on either the DWS06 Or Michelin AS3.
I will use my stock 18" wheels with winter tires for the snowy season.
Thanks much!
Thanks much!
#19
That is true, I agree lots of it is personal preference.
What size is your wheels? 19x8.5 or 19x9.5?
#20
I emailed the manufacturer before buying to confirm best fit - here were the 3 answers
1. The 19x8.5" M310 in 5x112 with an offset of ET35 will work on your A6 with no issues.
2. It is hub centric to your A6 with a center bore of 66.6mm.
3. The M310 requires a conical seat lug bolt. 14x1.5mm w/ 28mm shank.
