2016 Audi A6 - fog lights
#11
I have LED headlights on my 2016 A6. The all-weather lamps go on only when the appropriate button (in the grouping that includes the rear fog lights) is pushed. As cornering lamps, they only go on when the turn signals are engaged and then only the side chosen (left all weather light goes on when turn signal is pushed to indicate a left turn, etc.)
#12
#13
As I understand it pressing the "all weather" light button on the dash activates selective LEDs within the LED Headlight array to give lighting appropriate for fog. Maybe the US version of the LEDs does not do this. I don't have the LED headlights so have no firsthand experience of how effective they are in real life, but I have also never found front fog lights of any type to be of much use
Edit: further investigation reveals this from 2012:
"High-intensity halogen headlights are a standard feature on the new A6. Xenon plus units that include new all-weather lights"
So, even if it were on U.S. models, it would not apply to LED headlights.
By the way, there appears to be some confusion between the terminology of "all weather lights" and "static cornering lights". They are two completely different things. All weather lights would be as described above for the halogens and the cornering lights are found on C7s equipped with LED head lamps as separate lights that point down and to the sides useful only for cornering. As mentioned, the all weather lighting operation may not be available in North America.
#14
My S6 has matrix headlights and the fog lights are built into the headlights. There are two buttons to the left of the headlight rotary switch. The top one is front fog lights and the bottom one is rear fog lights. The matrix headlights also have turning lights that come on automatically and light up the curb in the direction you are turning. Best headlights I've ever had. Just wish it remembered the last state of the automatic high beam, when you turn off the car.
#15
Thanks for posting. The trouble is the video doesn't say where he got the fog grill from?
I ordered one from online for audi A6 C7 but it doesn't fit. It's ment for 2015 not 2016.
apparently they there is difference. Even taking it off is different.
#16
IMO..true foglights are a must-have *if you live where you need drive in dark rainy/foggie conditions. Real fog lights are very close to the ground and project a beam low..higher up lights will never be as effective since they bounce light back. I personally need them since I live in potentially rough winter weather (this AM: sleet/fog) then throw in a few winter trips to montana for TG'ing and Xmas and my 09 sixer excellent halogens have saved the night many times..
..I may not update cars (not much reason really) until find a proper FL mod for my next a6 or maybe a4.
#17
#18
Wire them up independent of the headlights and you can control when they are on.
Here's a eBay listing of one as an example of the size and shape.
17 034 144W CREE LED Light Bar Flood Driving Lamp Jeep 12V24V 4WD Boat SUV ATV Fog | eBay
#19
There are plenty of LED light bars that could be used on your next Audi. See what is available and where they would fit on your car.
