A6: C7 - Changing the front brake pads
Has anyone done a pad change on the Audi A6 front brake pads. If so, was it difficult and also if anyone wants to give advice about which brake pads have worked out best for the C7 version of the A6 please feel free to chime in. From my own experience changing the pads looks easy enough but never having done any brake work on an Audi I'd appreciate it if anyone who has, please chime in.
Thanks.
Thanks.
I did mine a few months back. Fronts are easy. Nothing really different from any other front brake job. As for pad recommendations, I went with Akebono ceramics. Though I hear EBC Red Stuff pads are good also.
Calimus,Thanks for the input. The ceramics, I thought your car needed some sort of special rotor to use the ceramic pads, I see I was wrong therefore I think I'll go with the Akebono pads as I'm sure the ceramics will cure any speaking problems. Thanks again.
1Guitar
1Guitar
No problem. Keep in mind that to do the rear brakes properly, you need a Vag-Com to fully release the electronic E-brake system. There are those that have done this successfully without the Vag-Com, but I wouldn't recommend it.
Besides, if you're in Jersey, it shouldn't be hard to locate one of the members here that has one that would help you out for a pizza/beer combo lunch.
LOL just be very careful with rear brakes.
I learned the hard way (I have a VAG come) but didn't know is needed for ebrake......PLUS accidentally activated the ebrake when the calipers were OFF!.....
it was not pretty.......luckily I found a used caliper for $100 as a replacement
https://www.audiworld.com/forums/a6-...agcom-2888072/
Thanks.
Thanks.
Nice job on the front brakes on the A6. One question, if you know, what is the torque value for the two bolts that hold the brake caliper onto the wheel? Good luck.
