Any vag-com settings for these?
#41
If you wouldn't mind, please do an auto-scan now and email it to me (PM for address) - I'd like to compare with my 04/14 build.
-undo the coding
-reboot MMI
-confirm no remote options
-redo the coding
-reboot MMI
-turn on remote options
-close all doors and try window down with remote
As a note on the C5, the windows-with-remote-feature doesn't work if any door is open - dunno about the C7 as I didn't have a chance to code this before giving up the car for shipment.
#42
Hmmm, seems like an Auto-scan before and after every dealer visit should be on my (and everyone's) plan....
I'd try this:
-undo the coding
-reboot MMI
-redo the coding
-reboot MMI
I'd try this:
-undo the coding
-reboot MMI
-redo the coding
-reboot MMI
#43
ETA: Did you ever run an auto-scan before? VCDS would have saved it too I think - would be *REALLY* interesting to know what the car looked like pre-update...
#44
I scanned it when I bought it just to check for any fault codes, but since it was all clear (no faults), I didn't end up saving it, unfortunately.
#45
So it DOES look like your Central Convenience was changed.... possibly this visit.
Just to be excruciatingly clear - you tried recoding 46 Central Convenience *BACK* to the non-remote setting?
#46
Yes. I tried going 100% back to the original programming, rebooting MMI, to no avail. I also tried activating Byte 2 Bit 3. When this was working originally, before this last dealer update, I didn't have that selected and the window up/down worked perfectly. So, I've tried it both ways by activating bit 2 and bit 2 + bit 3. Every time I re-code, I reboot MMI just to be sure/safe. It doesn't matter what combination I try now, it just doesn't want to take....and just to be clear, I DO see the options in MMI under the central locking and they are ON, but it doesn't work.
Der Kimbo
04-06-2006 10:05 AM
nicetts
01-25-2002 01:50 PM
