audi a6 4g without air susspension can i make it go higher or lower!
hii guys i have bought a audi a month ago and im interested to make a bit lower or higher im not sure but my audi is without air susspension so is it possible for it using VCRD Program! thank you.
Where are you located? In NA, there is no adjustable suspension available with an A6 C7. In the ROW it is an option. Since different hardware is involved, there is no way to add it just through coding. If you want to lower the car, there are various suspension components you can buy to replace yours.
I believe KW make a hydraulic lift component that works in conjunction with their (lowered) coil-over kit to do what you want. Except I doubt it can be controlled via VCRD - they would use a separate switch. The combined cost of the two is likely very expensive.
Цоньо Стойнов
09-15-2017 04:29 AM
BMWBig6
9
09-13-2008 11:16 AM
ayap
10-16-2005 06:00 PM
