Black sut around tail pipes
#11
100LL - is 100 octane, leaded fuel available at many airports.
The engine was a 1.8L, air cooled (essentially), Type 1 (bug) VW engine with approx. 8.1 compression.
Tried ethanol free, unleaded premium (about 93 octane). Got noticeable soot from the fuel. Although I didn't like the way the engine ran, others who use it have noted more soot than the older style leaded fuel. The leaded fuel also seems to be more stable and can be stored longer without additives.
The flip side is, that for some engines, the leaded fuel creates deposits that have their own issues for rings/valves/tappets.
No free rides.
No free rides.
#13
ScrewGuy
Thanks for the tip on the Simichrome Metal Polish. I ordered some from Amazon and when it came in, WOW! Sure did the trick! Just for grins I looked at the cost of tailpipe extensions, blew me away with MSRP of $350 each! I'll stick with the Simichrome Metal Polish.
#15
DI engines produce soot for reasons similar to diesels. The fuel droplets do mix with air before entering the combustion chamber and some of the fuel droplets hit the piston before vaporizing. There is less time for the fuel to be absorbed/mixed with the air. This forms more soot.
#16
Today's engines have much cleaner combustion than the older cars and they try to get a perfect swirl before ignition to eliminate the pollutants. Additional soot would clog cats in no time, would fail pollution limits, be less efficient and increase fuel use.
DI is only possible today because of todays faster computers. DI in the old days was dump approximately the correct amount of fuel then add a bit more because what you don't use will be thrown out of the tail pipe. Those days are over.
Carbon build up has been an issue with DI however but most of that inefficiency is due to the engine not being up to temperature.
#17
I am not convinced.
Check out the attached ( slide 23 for EU and slide 25 for the US market)
http://www.cargroup.org/assets/speak...idt_oliver.pdf
#18
It's getting very complicated. The good old days when Cadillac wanted to increase torque they just increased the engine size until they got up to 500 ci and then realized that there must be a better way! Now the challenges of pollution and MPG's are exponentially advancing. I see 3 cylinder/hybrids of 350 HP in our future?
#19
#20
soot removal
A8 uses 93 octane, causes some soot, got rid of the black stuff w/ Terminator from 'Stoner' (same brand as Invisible Glass)
it may be hard to find or use WD 40 with a paper towel. It has worked fine for the chrome w/ soot. You can use steel wool "0000" extra fine also but only if its stubborn...
