Can the digital HVAC control panel be retrofitted to a 2 zone climate control?
#11
Ok thanks for the reply.
Did you do any additional coding to the module or did you just swap it without doing anything? I went in to the controller yesterday and you can set it to be climatronic high or low, so i think i can get it to working in a good way even if i swap it.
I really hate the analogue version so i gotta swap it
#13
The anti-theft ID you are referring to is "component protection" which essentially means that any electrical component in the car, once installed, is paired with the car. Should you move the part to another car or buy a part from another car then you have to go through the process of pairing that component with your car. Officially this has to be done by an Audi dealer but there are people out there who will do it for you.
#15
Apologies for necro-ing this thread, but I am searching for the part number for the rear climate control panel. The plastic cover for the LCD screen is missing, and evidently it is only available as an assembly... Seems kind of crazy to pay for the entire assembly, but I can't even find the assembly part number. Wondering if anyone has it and could share it?
#17
Exactly what I discovered today when i took the analog climatronic unit out . I only have 2 connections and on the new digital unit i have 3 connections . did you manage to solve this problem ? how to connect ?
#18
additional wires are for the extra servo motors on the blower unit and temp senders for the rear ducts.
Ive done the full 4 zone retrofit and its a full dash out and complete blower/matrix unit replacement along with extra ducts under the carpet
#19
So please tell me , if i just want to take out the analog climatronic with 2 connections and I will connect the digital climatronic unit , it will still work ? I know that it will not work properly and i need as you say extra sensors and blower unit . But i just want to have the front digital unit installed and i know it will not work as it should and i will have errors in vcds but was wondering if it will turn on and partially work.
#20
Once you remove component protection from the unit, yes it will work but only partially. Yo will not have full control over where the air is blowing. In these cold days you may want full power to the screen for demistings and you will not get it and windows will will steam up quickly.
