Chipwerke piggyback results
#401
Dual pulley refers to an underdrive SC pulley and an overdrive CP used in unison. There is no custom tune for this available that is widespread (although EPL has some versions available I believe). People are running their stage 2 tunes on the dual pulley cars. Because the car is programmed with boost targets that would now be far below what a dual pulley car can make for boost, you need either a different tune or you can use CW. CW makes the sensor see less boost that the car is actually making thereby making the ECU think it is not hitting boost targets and then the ECU closes the bypass valve. This gets you maximum boost. You're getting another few psi in boost. I gained about 50whp stage 1, another 30whp on my SC pulley, and i would guess people are seeing about another 25-35whp with dual pulleys depending on the size of overdrive CP they use.
Mike
Mike
#402
BHVRDR is correct. Here in tampa there are 2 guys that I know of doing the dual pulley tunes 1 on an s4 and another on the a6. Both ended up TD1.
The A6 guy ended up with a lot of engine problems created by too much power I suspect.
He apr stage 2 with no muffler and did 12.5. Then he added a new tranny shift mounts for stiffer shifts, awe cooler system, dual pulleys, apr stage 2. he added the CW to get more boost.
He could smoke all 4 tires and his p3 had 0-60 below 4 sec!!!
But he kept getting cam timing code 0018. WHich means the 2 bankls were out of sync until he had to take it to audi.
The timing belt had stretched and/or tensioner could keep up. Either way he was down.
#403
Mike
Mike
Sounds like I need to check the chain stretch first before increasing boost.
Thanks you much for the helpful advice and teachings!
#404
#405
I have had it installed in my 2014 A7 for about 3 weeks and I got my first CEL last week. Ran ran fine with the CEL on for a few days and then it started occasionally having a rough idle at red lights/stop signs. After enduring that for a few days it got worse and began dying at a red light and giving me a start/stop system error( which I usually have turned off). I could restart the car, continue driving but eventually it would randomly die on me again.
I got home, disconnected it, and cleared the codes. Car works fine back to stock, including the start/stop system. I want to reconnect the CW but I am leary.
Is it best practice with the CW to disconnect every few weeks and run stock for a day or so?
#406
#407
still getting these codes
VAG code is 9779 boost pressure P0235 regulation range not reached and 6307 MAP/MAF throttle position correlation P0068.
this is with a replaced box from CW
#408
Thanks Vodka.. I'm going to start experimenting with mechanical duplication to see if these same errors appear. Which would mean the software programmers of the chipwereke have gone to sleep on their product. Not making any accusations just yet. Need some time to investigate.
There's no such think as too much power. Just a failure to get it to transfer where needed (to the ground). More than likely there is errors in the management of the PCM/CPU software programming. Tuning engines is not easy... alot of variables to consider.
#409
Those are the codes I got after a year of trouble free operation. The code was triggered during a hard pull on an on-ramp in some 95 degree weather. After that the car would start rough, and run a bit rough under idle at times. I pulled the unit and flashed the codes out and everything is back to normal. I have not bothered to put the unit back on. While I love the extra boost for highway passing speeds with the CW, I enjoy the smoothness around town with the stock setup.
#410
Please check out the Harness for oxidation any point of male and female plugs and subD plug on the chip side..try oxidation remover or WD40.
