Dash cam - Blackvue
Dash cam - Blackvue
Hey guys, I've recently installed Blackvue DR650GW-2CH and it came with power magic pro to have the dash cam on all the time and shut off if it is about to drain the battery.
Now I've looked up on what fuse to tap into and tried it and the power magic pro is not getting power and the box is not defective since they have sent me a replacement one after I told them the one came with the dash cam isn't working.
Anyone know how to get it to power on or what fuse I should tap into?
Right now it's plugged into the cig lighter so when the car is on it powers on.
It has Red ( turns on when ignition is on), Yellow ( on all the time), and black ( ground wire).
The cigarette charger is switched.
You need a constant power source for the power magic so it will keep the camera on while the car is off. The power magic will shut down when the voltage gets below 11.8 volts.
Mine is installed on the passenger side of the dash.
You can't see the Power Magic in this pic because it wasn't installed yet, but we use the bottom fuse block and attached the Power Magic below it.
The cigarette charger is switched. You need a constant power source for the power magic so it will keep the camera on while the car is off. The power magic will shut down when the voltage gets below 11.8 volts. Mine is installed on the passenger side of the dash. You can't see the Power Magic in this pic because it wasn't installed yet, but we use the bottom fuse block and attached the Power Magic below it.
The problem is that you need constant voltage so you need to tap it on the driver side fuse box.
That's what is did for my BV550 2CH on the side note I prefer it over 650 because of the wider lenses. Any how that's how I did mine. Don't remember exactly what number fuse they are but it's been working fine past 2 mo. As you can see I'm using add a fuse thing. And I'm happy to report that it records solid 8h while I'm at work parked on street
On the other hand I should probably add (since I cant edit my post above ^) that I did not check the passenger side fuse box for voltage because I wanted to have magic pro on drives side any how. Multimeter is your best friend to find voltage and then refer to manual what is what and tap in.
Edit: also where did you ground the black wire to? I grounded mine to the bolt above in your picture.
Did not drive my A6 today, I have Demolition in progress next to my work :/
When I get home I will post all necessary pictures. And Ad a fuse thing you will need two sizes I'm sure you can notice from the picture above. As far as the ground goes I used the bolt in top left of the picture with modification will post picture.
Did not drive my A6 today, I have Demolition in progress next to my work :/ When I get home I will post all necessary pictures. And Ad a fuse thing you will need two sizes I'm sure you can notice from the picture above. As far as the ground goes I used the bolt in top left of the picture with modification will post picture.
Before is start just want to mention that I did this all myself and it worked out fine I'm not electrician by any means but I like mess around with hardware. It works fine for me but if something goes wrong for anyone else I'm not responsible. This in not a guide how to do it this is my example of doing it.
First position of the dash cams
Passenger size fuse box :
In order to ground the Magic Pro to The Bolt in the fuse box I needed to cut off the end terminal (it was to small to go on the bolt) so I replaced it with Spade Terminal #10
Cable management :
Red for power
Green for Video
And that would be about it its not the best job out there but I'm happy with it and people who get in to my car don't even notice stuff so job well done.
Cable management :
Red for power
Green for Video
Before is start just want to mention that I did this all myself and it worked out fine I'm not electrician by any means but I like mess around with hardware. It works fine for me but if something goes wrong for anyone else I'm not responsible. This in not a guide how to do it this is my example of doing it. First position of the dash cams Passenger size fuse box : In order to ground the Magic Pro to The Bolt in the fuse box I needed to cut off the end terminal (it was to small to go on the bolt) so I replaced it with Spade Terminal #10 Cable management : Red for power Green for Video And that would be about it its not the best job out there but I'm happy with it and people who get in to my car don't even notice stuff so job well done.
Thanks!!
