Drive Select Default - AudiWorld Forums
A6 (C7 Platform) Discussion Discussion forum for the C7 Audi A6 produced from 2011
Old 04-07-2014, 01:07 PM   #1
Glacier6's Avatar
Default Drive Select Default
I believe I read on the forums before that no matter what mode is selected (Auto, Comfort, Dynamic, Individual) it will revert back to a default setting, that is basically Comfort, every time you turn the car off and restart it. I know I can just pull back the stick to put it in S mode but I prefer Auto most of the time.
Is there any way to have the car always remain in the selected setting? It's pretty annoying to have go into the car menu every time I start it and select the mode again.
Glacier6 is offline   Reply With Quote
Old 04-07-2014, 01:17 PM   #2
snagitseven's Avatar
I believe with VCDS, the start up default can be changed (try a Forum search for details). Note that only the throttle and gear maps are affected; i.e. steering, ACC and seat belt settings are remembered.
snagitseven is offline   Reply With Quote
Old 04-07-2014, 04:29 PM   #3
Maybe I'm making this up, but I swear my 2014 A6 remembers the last mode it was in when I power up. I have been keeping mine in Individual mode so that I can have auto everything but comfort adaptive cruise.
jdong is offline   Reply With Quote
Old 04-07-2014, 04:46 PM   #4
Glacier6's Avatar
Quote:
Have you tried placing it in Dynamic and seeing if it stays in that setting after you restart?
Mine is a 2013 so hopefully they did change that.
Old 04-07-2014, 04:49 PM   #5
keithl's Avatar
My 14 remembers previous settings.
keithl is offline   Reply With Quote
Old 04-07-2014, 05:28 PM   #6
gatorguy7's Avatar
My 2013 remembers what I was in last minus the 'S mode'. However, there was a S6 owner who found a way to create Dynamic 'S mode' as default.
gatorguy7 is offline   Reply With Quote
Old 04-07-2014, 07:00 PM   #7
That's because when you start the car it defaults to Auto which is what you set in Individual (throttle and transmission only; ACC remembers what you set set).
Old 04-07-2014, 07:28 PM   #8
DeerHunter's Avatar
Mine stays in Individual. Like any memory function, such as seat and mirror positions, it probably needs to be linked to your key fob. Simply set things the way you like them, exit the car and then lock with the fob (not the door handle button). The next time you start with that fob in your pocket, things will be as you left them (except, as noted, 'S' mode, which always resets to off).
DeerHunter is online now   Reply With Quote
Old 04-07-2014, 07:39 PM   #9
Glacier6's Avatar
Quote:
So the throttle/engine will remain in Auto as well? Is it only Dynamic and S that reverts back?
Old 04-07-2014, 07:42 PM   #10
Quote:
Dynamic in the MMI and S mode on the shift lever are one and the same for throttle and transmission gear maps.
Thread Thread Starter Forum Replies Last Post
Summary: C7 Audi Connect Carriers and Options snagitseven A6 (C7 Platform) Discussion 146 02-24-2017 08:48 AM
How to mirror your phone on the MMI screen markN1689 Audi A3 / S3 /RS 3 MKII 149 01-13-2017 02:21 PM
Snow Tires: Nokian or Dunlop? scott98101 Q5/SQ5 MKI (8R) Discussion 61 02-05-2016 06:17 AM
New member with a few questions scottnybottny A8 / S8 (D3 Platform) Discussion 0 09-05-2015 11:52 PM
New Owner Air Suspension Questions scottnybottny A8 / S8 (D3 Platform) Discussion 0 09-05-2015 02:35 PM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
