Driving and Stopping in Snow
#11
Many of these pearls of wisdom are handed down from the olden days of manual transmissions and drum brakes. I feel that if a transmission can handle 400 lb/ft of engine torque, it can handle downshifts
#13
So, while these trans may be perfectly capable as both of you suggest, I think about the additional inputs to the driveline, the motor/trans mounts, etc., as one more but unneeded load when the brakes could handle it just fine.
Probably sounds a bit neurotic, but I'm aware of it....and much of my stuff lasts a long time in great shape!
#14
Exactly. Otherwise, we should drive like little old ladies on the way to the tea social for fear of breaking something or cover our sofas and chairs in plastic so they don't wear out. My motto is use it or lose it. Make full use of it as it was intended or, in this case, why have a high performance luxury car at all?
#15
#17
I typically use Tiptronic downshifts from time to time to assist in slowing down on slick roads. Of course, on the way to social teas I use the Loud Pedal mostly – can’t wait to start the gossip lol!
My question in this discussion relates to the use of transmission slowing (on icy roads especially) not taking advantage of the anti-lock functionality that one would gain in using foot brakes. Is this something to consider?
Two things: 1) At least a few years back, most ABS systems did not function under something like 5 mph – so maybe in the last few yards of stopping it doesn’t matter; 2) I sometimes downshift and brake at the same time. Is this a way to get the best from both engine braking (via tranny downshift) and the anti-skid properties of ABS?
FWIW – I love Earl Grey, dear!
#18
#19
I believe the traction control system would intervene when using the transmission, even if no brakes applied. It won't trigger ABS but it still could be more effective than braking to slow down a bit in certain conditions. You could use both but you're goal is to minimize any slippage so you want to give yourself enough room for a gradual reduction of speed, with whatever method.
Giving plenty of distance in bad weather is always a good idea. I usually use both downshift and brakes in slippery roads as gradually as possible. Any sudden action of any kind on ice or snow covered surfaces can cause loss of control. I call it driving and stopping as if on eggs.
The key is to leave plenty of room and try to anticipate from farther away what other drivers may do, even more so than normally. It's sort of like driving an oil tanker - it takes longer to stop and steer the ship.
