EPC light and oil pressure sensor code
under hard acceleration EPC light comes on and 4k rev limit light, scanned with vag and found an oil pressure sensor code. I want to pull the supercharger to replace the sensor and check wiring. Any thoughts on torque specs for supercharger bolts and if the gaskets are reusable or not? supercharger pull write-up on this would be helpful being that the thermostat is under there too.
I can't help with the torque specs or the gaskets. However, this same issue took place on my car under hard acceleration. Dealer stated cylinder 4 ignition coil was faulty and they replaced. No problem since.
Just left the dealer earlier today and learned that the oil pressure sensor that needs replacement is behind the intake and above the trans- not under the supercharger!. There are two sensors next to each other and only one needed replacement. It is a blind reach around job-making it hard to start threads on new sensor install. Sensor was only $15.
smurfy
07-14-2002 05:09 PM
