Headlight indicator? - AudiWorld Forums
A6 (C7 Platform) Discussion Discussion forum for the C7 Audi A6 produced from 2011
Old 06-13-2014, 07:31 PM   #1
Default Headlight indicator?
Ok, so this feels like one of those stupid n00b questions, but I don't recall seeing one while I had the car, and I can't find anything about it in TFM....
With the headlights on AUTOMATIC, is there any (interior of course) indication that they're on???
TIA
Richard Solomon is offline   Reply With Quote
Old 06-13-2014, 08:58 PM   #2
TIA
Interesting question. My answer: Not that I know of. I guess just the rotary switch in the auto position. If you flick the light stalk for high beams you will see the blue (I think it is blue) high-beam indicator, but beyond that I don't think there is anything else. I sometimes have to look around to see if I can see my lights reflected in some surface like a shop's glass window, but I guess really no indicator saying "the lights are on"
irenesbob is offline   Reply With Quote
Old 06-13-2014, 09:08 PM   #3
dwboston's Avatar
Quote:
The Nav screen changes to "night" mode when the headlights turn on via the Auto selection. That's the only indication I've seen that the lights are on.
dwboston is online now   Reply With Quote
Old 06-14-2014, 12:49 AM   #4
DVE
DVE's Avatar
There is an indication. If the rotary switch is on AUTO and the lowbeams are activated the yellow marked symbol is green illuminated. Unfortunately it is permanent illuminated if you have coded on "scandinavian" (means drl and rearlights are on).
DVE is offline   Reply With Quote
Old 06-14-2014, 04:12 AM   #5
snagitseven's Avatar
Quote:
Unless, of course, if you have the nav screen set to "day" full time. (i'm not fond of the night mode).
snagitseven is offline   Reply With Quote
Old 06-14-2014, 07:06 AM   #6
newmoon's Avatar
The backlighting for all of the buttons like the HVAC controls, etc will light up red when the headlights are on right?
newmoon is offline   Reply With Quote
Old 06-14-2014, 07:13 AM   #7
Quote:
No, not necessarily. If the headlights are activated because, for instance, your wipers are on, but there is still sufficient daylight, the inside backlights and other inside nighttime illumination will not be activated.
The answer to the OP is that the only indication is as DVE said, the headlight marker lights up. Unfortunately it is a real pain to see it (I am tall and the angle is horrendous). It would be nice if there was a dashboard indicator, but at least there is something
Alphatero is offline   Reply With Quote
Old 06-14-2014, 12:49 PM   #8
Quote:
Thanks to you both! I recall that I too had a tough time with the angle to the headlight switch - it's IMO intended to be operated, not observed - so Audi putting the auto-light indication there is odd. I think the C5 auto-lights showed up in the instrument cluster - with all that the C7 cluster can do, it's sad there's no lights-on indication
At least I can probably remember to look at the light switch if I want to know whether they've come on or not. Sure would be nice if there were a way to recode via VCDS to make this better!
Old 06-15-2014, 02:05 AM   #9
I always found it crazy that there are dash indicators if the clock is getting the time from GPS, auto high beam, high beam on, but nothing for low beam lights when on auto.
Surely a GPS clock indicator is less relevant than headlights, especially when the switch is prone to knee bumps.
cdbrawn is offline   Reply With Quote
Old 06-15-2014, 03:43 PM   #10
newmoon's Avatar
Honestly, I haven't seen the headlights come on just because the wipers come on. Because there's been a couple of times when I'm sitting behind another car and the wipers are on, but I can see the reflection of my lights and only the LED running lights are on (which are actually quite bright). So I go ahead and manually turn on the headlights. Maybe it's only LED headlights that come on with the wipers? I have a Premium Plus with HID headlights.
Thread Thread Starter Forum Replies Last Post
Fault Codes Kerry G Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 3 06-07-2016 03:55 AM
:: ECS Tuning :: NEW!! B8 S4 ECS Performance Lightweight Flywheel ECS Tuning-Audi S4 (B8 Platform) Discussion 2 03-27-2016 07:49 AM
:: ECS Tuning :: NEW!! B8 S5 3.0T ECS Performance Lightweight Flywheel ECS Tuning-Audi Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 3 02-04-2016 09:36 AM
Help with 2005 Audi A6-3.2L quattro BKH bballfreak A6 / S6 (C6 Platform) Discussion 4 10-12-2015 06:14 PM
2015 Q5 TDI 5,500 miles...Glow Plug light flashing.. SJGQ5 Q5/SQ5 MKI (8R) Discussion 4 10-01-2015 09:44 AM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
