iPhone 5s connection
Old 11-24-2013, 08:02 AM
zamalek's Avatar
Default iPhone 5s connection
Hello everyone, maybe this subject has been discussed before but I research it with no luck, I recently switched from iPhone 4S to 5s, the former hooked up to the car's ami cable with no problems, now the 5s is got the tightening 8pin connector, do I change the cable supplied by Audi (USB to 30 pin), do they even have a cable that is USB to 8pin, or do I have to use apple 30 to lightning cable with the existing cable, all aftermarket cables will charge the phone but don't support audio, only apple cable does, need some help please, thanks
Old 11-24-2013, 08:49 AM
snagitseven's Avatar
Everything you need to know as of today about the AMI cables and the lightning connector can be found here:
https://www.audiworld.com/forums/sho....php?t=2840907
There is an indication of a new AMI to lightning cable but it's not confirmed or apparently available yet.
Old 11-24-2013, 08:56 AM
zamalek's Avatar
Great info, thanks a lot for this, very helpful
Old 11-26-2013, 04:05 PM
agjil's Avatar
I asked my local dealer about the iPhone 5/5S cables, and was told that they are not available yet.
It's been more than a year since iPhone 5 came out...how can it possibly take so long for this..
Old 11-26-2013, 04:13 PM
Banned
Mike_L's Avatar
Nobody has them. BMW and Benz don't either. The Lightning cable is all digital, so its completely new. Its going to take time for all the manufacturers to figure them out.
The Apple Lightning adapter works perfectly. Use that for now. Cheapo Chinese ones don't work, so don't even bother trying. I already did.
Old 11-26-2013, 06:02 PM
There's a brand new cable, 4F0 051 510AC that is purported to be an AMI Lightning cable - it's available at a couple of online suppliers (Google the part number). I suspect this new AMI cable will have some kind of DAC built in similar to the 30 pin to Lightning adapter currently available (the AMI can only pass analog audio). I've not seen anyone who's tried one yet so it's unclear at this point if video will pass through to the MMI which the Apple adapter cannot do.
Old 11-26-2013, 06:18 PM
Banned
Mike_L's Avatar
Its showing up as "backorder/unable to order". Its also $90 Retail.
Old 11-26-2013, 07:53 PM
Did you try these? Also less expensive.
http://www.worldimpex.com/parts/genu...r_4041949.html
http://www.eurothenticparts.com/oem-...4f0-051-510-ac
Old 11-26-2013, 11:10 PM
Banned
Mike_L's Avatar
I'll check this afternoon. If they don't have them in stock, they won't be able to get them either if they're backordered, so hopefully they do.
Old 11-27-2013, 03:44 AM
DirkM's Avatar
4F0051510AD seems to be a newer revision for less money
http://www.worldimpex.com/parts/genu...r_4041950.html
schalliol
10-12-2015 05:57 AM
PainDOC
09-29-2015 06:55 PM
markN1689
Audi A3 / S3 / RS 3 MKII
09-08-2015 07:59 PM
petebest77
01-26-2010 09:52 AM
Quick Reply: iPhone 5s connection
