how to turn off bumper sensor beeping?
Old 09-27-2015, 06:05 PM
random512's Avatar
Default how to turn off bumper sensor beeping?
Hi, how do you turn off the bumper sensor beeping? Going through a car wash is quite annoying with the sensors/beeping enabled.
Old 09-27-2015, 08:24 PM
snagitseven's Avatar
Your manual will explain how you can adjust the proximity sensor volume - it can also be set to zero in the MMI sound settings as well as changing the frequency of the beeps.
Old 09-28-2015, 12:01 AM
John Simcox's Avatar
Button on the dash above AC controls
Old 09-28-2015, 03:06 AM
DB22's Avatar
I think that your answer may depend on the model, options and location but the OP doesn't state any information. I do not think that the US models have a switch, at least on the C7.0.
Old 09-28-2015, 03:13 AM
random512's Avatar
I have a 2016 A6 with Prestige Package. I hope there's a way to disable it. The beeping makes car washes really unpleasant.
Old 09-28-2015, 04:49 AM
Have you read your manual?
Old 09-28-2015, 06:35 AM
Switch with "P" next to the passenger airbag warning.Not sure why the OP has a problem unless he has put the car in reverse first as that is required to activate the parking sensors (or has Audi bowed to complaining ex-Lexus customers and made the front sensors permanently active)
Old 09-28-2015, 07:06 AM
DB22's Avatar
I think that you are correct with going in reverse first but I have never taken my Audi to a car wash or have ever turned the sensors off. The only time that I ever use the P button is to turn the front camera on when going forward into a parking space.
Old 09-28-2015, 08:17 AM
I did have to "Google" car wash as I could not understand how you could be outside carefully washing your car and inside hearing the beepers
Old 09-30-2019, 10:07 PM
Jeando's Avatar
Default 2011 A6 Quattro sensors beeping
When I put my car in reverse the sensor alarm goes off. I tried cleaning the front and rear sensors, but that didn’t work and I do not see a place within the car setup screen to change this alarm. Can you help?
Thsnk you, Jeannine
Quick Reply: how to turn off bumper sensor beeping?
