Inexpensive Intercooler Improvement Experiment DIY
#11
I'm curious as well since I believe the heat exchanger for the S6 is basically the same as the A6 and I would figure it has to deal with more heat from two snails vs. the supercharger. I have the same thought as you, "if they could have made it larger/better why didn't they?" Maybe to share the part across all three 2.0T, 3.0T, 4.0T?
#12
#13
This intercooler is rated at 450 crank HP and measures 25.25"x8"x3". End tank to end tank is 35.5".
Anybody that publishes this misleading BS shouldn't be given the time of day. It implies that a 1.8T VW will get 425HP. I know it's an implication and not a statement but reducing the temp to increase the density of the cold air is advantageous but not by much over the stock intercooler. You could remove the intercooler altogether and only drop less than 20HP.
#15
A 1.8 car producing 450 crank HP?? WOW!
They forgot to mention the need to beef up all the internals and pair up larger turbos with a Nos Kit to get up there. Plus that's obviously engine (crankshaft) HP not wheel HP given cars lose anywhere from 15%-25% HP though drive train power transfer.
#16
I think that ECS means that that intercooler will support up to a 450HP engine and not that if you buy and install your engine will "make 450HP". That is how I understood it.
#17
Keep in mind everyone that this is specifically why I titled this thread an "EXPERIMENT". Results to follow.
#18
That's how I read it too. After all, ECS couldn't possibly know what the stock HP would be before installing it nor would they make ridiculous claims or false advertising. ECS is a proven, reliable company and over the many years our members have been doing business with them, I've not seen complaints.
#19
This might help you to better understand the cooling system on the 3.0 V6 TFSI. (Pg32)
http://www.s4-mtm.com/images/925803_3.0V6TFSIengine.pdf
#20
That's very interesting. I've now seen MANY graphics showing a full size intercooler radiator much larger than the smaller unit installed on my 2012 A6.
Wondering if the 2012 came with smaller intercooler radiator while later years were upgraded to larger unit? Makes sense if the 2012 is the first version of the C7.
Got some homework to do it seems.
