ISO: Cleaning Tip - Area around rear license plate on trunk lid
Where ever the original owner got his car washed, for some reason, it seems that the area to the left and right of the rear license plate, just below the trunk lid lip (below the camera, plate lights, lid release) never really got cleaned. There seems to be a film for about four inches wide all the way across the that area. A little elbow grease is not doing the job. Below that area all the way to the bottom of the lid is clear and glossy.
What have others used that won't affect the clear coat. Honestly, with all the cars I own or have owned, I have actually never experienced this.
Thanks.
AGE
Thanks.
AGE
If it were mine, I'd start with a clay bar and lubricant and then a light polish (I use Griot's and Wolfgang) and work up if needed. You probably won't get a buffer in there so start light with circular motions with a hand pad. Clean off with microfiber and you'll need to replace the wax or final coating of your choice because the polish will take that too. Your clear coat should be fine but a good rule is to go as least aggressive as gets the job done.
Shouldn't be a big issue and let us know how it goes.
AGE
I'll start looking into compounding agents for "Plan B."
AGE
My guess is that the original owner used a car wash exclusively and possibly just drove off after cleaning. During the winter months I use a couple of different automatic car washes (water jets only - no cloths) and notice that the area you mention often is not as clean or rinsed as the other parts of the car, especially in the upper corners near the trunk lid above the license plate. Any soap residue left there becomes a magnet for more dirt and grime. Yet another reason for wiping down after a washing. I wouldn't be surprised if the door jambs were also grimier from the original owner.
Oops. It's on there. Wolfgang uber compound is one of the newer ones that cuts nicely and the abrasives diminish as you use it. If you need to get that aggressive, don't forget to hit it with a fine polish at the end before protective coat. WG has a finishing glaze that I like. Everyone has their favorites and pick a higher end product, imop. Autogeek is where I do plenty of shopping. You'll get there.
