Keyless Entry
Keyless Entry
So I have a 2012 Audi A6 3.0T Prestige.
I recently discovered that my keyless entry works about 85% of the time. This is a recent discovery though, not sure what is going on with in. I'm hoping that the battery for the fob is becoming weak? but I do not know how these things work exactly. Has anyone had this problem before, if there is a thread that would be great if a link could be posted. If this is a larger problem than it is, the car is covered for electronic problems such as this.
Thank you
Thank you
you mean when the fob is in your pocket and you pull the door handle to unlock the car? if so, grab the handle but hesitate before you actually pull it (gives the electronics time to detect your hand on the handle) AND do not touch the lock button on the outside of the door handle while doing this.
The car shuts down systems when the battery is getting low to conserve enough power to start the engine. I think this includes the door sensors. You can still unlock using the button on the fob right?
The dash normally gives you a message when the battery in the fob is getting low.
Yes, I thought it was the fob's battery dying at first, but I have not had any pop ups on the car stating the fob battery is low. Also, to answer your question I can still use my fob to unlock the vehicle, but I am in love with keyless entry and it's a must have.
Yes, if the car has been off for several hours, systems go to sleep including the door sensors. But no need to use the key - as the manual states, the door handle will need to be pulled twice - the first to wake up the lock system and the second to unlock the door.
I have done this actually, I even have it on video just incase I have to show proof that this isn't working. I pulled it about three times and nothing happens. I called the dealership in regards to this problem and they wanted to start by replacing the key fob battery to eliminate that theory. I am really hoping that is the case, because I want my keyless entry back. Also, I actually turned the car off walked away for about 10 minutes came back to test it and still nothing. So, at this point I have no idea what it is.
Replacing the FOB battery is a good place to start though.
The dealership said that they would replace my battery free of charge and inspect it right then and there incase it isn't a quick fix. Also they only thing I installed is just a Bluetooth adapter for my media, but its been installed for a few weeks now and the problem just started 3 days ago.
