LED cabin lighting
LED cabin lighting
Hello. I installed the original LED cabin lighting.It does not work as it should. after opening the door does not light up. lighting the rear cabin of the control panel is not working. Does anybody know how to do it?
If everything is truly setup correctly hardware/wires wise, then I would assume a VAG-COM adjustment?? (Don't know if you swapping out a regular light bulb unit with a LED or what?) I would say its weird for a cabin light to go through the cars' computer, but we are talking about VW methods of German Engineering.
Start with the basics and check for power. You may have blown a fuse during installation.
Some vehicles have 12VDC on all the time and switching comes from the ground (earth) side. That allows for door closed dimming and full power reading lamps from the same bulb since they have two ground wires.
LED cabin
plugs are different.They have more PIN. therefore, probably not everything works. maybe some sort of adaptation? I have VCDS.
I have a normal cabin lighting but wants to have LED original
Where did you purchase your unit? Thanks
led cabin
I paid for everything that is 650PLN $ 180 yours.
I plugged everything (LEDs front) rear LEDs
It does not work when you open the door, and when you open the car.
I just came across this and watched your video. Do you realize that the button on the back right that you toggle on and off must be on for the door to activate the LED lights? That's the issue, I'll bet. When I first got my A6 (May), the lights were not coming on when the door was opened. I looked in the manual and it mentioned that toggle switch. I have it on (i.e. luminated red) and the LEDs come on when the door is opened. Try that and see if it doesn't work.
Yes, I tried that, it still didn't work.
