LED trunk light(s)?
#11
Try this:
https://www.wiredco.com/LED_Lighting...age_s/1874.htm
On the same page is a dimmer module with a remote. You can either run a strip or bulbs and then on/off and dim with a remote. Overkill but some may like it, I have 2 lighting my patio.
#12
The other factor for searching is the length in centimeters. 300 cm is about a foot and it's a common length. One meter is another common length. The roll in DVE's link is 5 meters and you can cut to the length that fits. The strips are wired in groups of three and there are marks showing where to cut.
You want to make sure that they are waterproof which mean that they have clear PVC over the strip. Non-waterproof will work but it leaves the lamps exposed. You also want to make sure that they have double sided tape on the back. Cool white has a bluish tint and warm white has more red in it.
I buy mine for around $1.50 per foot unless it's something special. I get the best deals by placing the bid in the last 15 seconds.
The 5050's shown in DVE's post are RGB's (red-green-blue). You vary the ground to the lamps to make any color and brightness you desire. They usually come with a controller box and a remote. I have one on my wifes visor and she uses it as a red reading lamp on long trips.
Search using "led strip" and sort by lowest price and shipping. Add descriptors such as 5050, 3528, 5630, white, cold, cool, warm, etc. to narrow your search. The lowest cost strips come from the Pacific Rim so allow 2-4 weeks for delivery. Test the strips across your battery before leaving feedback. I've had a few dead lamps and got a full refund from PayPal. Life expectancy is around 2-3 years so you might want to have spares. Sometimes one of the three lamps go out usually due to the resister failing.
Here's a shot of my LED rack
#13
I've bought dozens of LED strips from eBay. There are several types which are found by specified by the lamp size. The newest and brightest is the 5630. The 5050 and 3528 put out the same amount of light per foot. 5050 is brighter but 3528's have more lamps per foot.
It feels very AWOT'ish to say this, but... Nice rack!!!
#14
I replace the original trunk bulb with LED one 2 weeks ago. Normal LED that I bought from ebay for $4 (3pc) works awesome in my Cabriolet. Actually everything will be good in the miniature trunk of the cabriolet
Purchased 37mm LED thinking that will fit in the interior light, but it turned out the interior is 41mm long so I just tried the 37 in the trunk and it worked perfectly. When you buy have on mind to look for CANBUS chip because the LED has lower wattage than normal bulb and thats why you may have a code for problem with the light. On my Cabriolet there is not that much electronic things
#15
The prices at the home centers and FLAPS are sky high. As for the color, go all out and buy a two or three foot strip of each than compare them to the interior lamps when you test them. I personally like the cool or cold white for trunks. I had to switch my powder room light to warm white when the cool whites blasted the little room. The warm whites look close to a standard incandescent bulb. The cold whites are used in most LED flashlights.
DVE's trunk pictures appear to be cold white LEDs.
#17
I bought a packet of 6 LEDs from EBAY for $8 and replaced the trunk and all 4 doors red lamps. I think that every lamp in my A6 now is LED.
BTW - unless you want to engineer these lamps then be careful what you buy. The shoulder on the plastic LED's is larger than the old bulbs and some bending of the socket was necessary for insertion. Also the length of the SMD assembly is an issue so the very bright ones are too long for the housing.
Although I am happy with what I did, increase in trunk brightness and, because I had them, I changed the door bulbs, I would not recommend this purchase due to the modifications necessary to the socket.
#18
The rest of the car has the LED lighting package except for the cargo bay lights and glove box, which makes absolutely no sense.
#20
