MMI Help!!! Adding iTunes Playlists to Jukebox
Old 06-30-2011, 04:54 AM
teddyoh's Avatar
Default MMI Help!!! Adding iTunes Playlists to Jukebox
Just picked up my new 2012 A6. Newbie to MMI. Initially had no problems with anything, and it operates great.
Having a ton of trouble with loading/playing music. Anyone with MMI experience to offer advice???
I loaded about 10gb music to a 32gb SD card (supported). Music was in folders by playlist. I then added the playlist files from iTunes in .m3u format (supported) to the top directory of the card. Did an import into the jukebox. I got only some of the songs across. Many others were left off the import with no pattern that I can see. All songs are .mp3. None of the playlists transferred either. The Jukebox playlist folder just has recently played, star ratings... NOT transferred by me.
Then, when I try to play from the SD card itself, those same songs are greyed out and won't play giving some file damage error. Files are fine when I put the SD card into my comouter. Playlists play from SD card, but keep stopping due to the above error.
There has to be a way to load 20gb music to the Jukebox.
There has to be a way to load your own playlists. How else could you manage all that music, and why would they have a Playlist folder?
The Audi manuals offer no extra advice or support.
Help!!!
Old 06-30-2011, 09:37 AM
CharlieSlasher's Avatar
Try searching Jukebox in the A8 or A7 forum as they both have the same exact system.
From what it seems, the Jukebox is a nightmare. The only reason I may use it in the A7 is that you can view your album artwork. I may just stick with the ipod though.
Old 06-30-2011, 11:02 AM
jetinder's Avatar
I just used Soundtaxi to convert my ipod media to mp3's and copied them over on either a USB stick or SD card. Unfortunately, I don't use playlists apart from the ones on the ipod.
I'll give it a go after dinner and see what happens.
Omeletpants
A6 (C7 Platform) Discussion
05-22-2018 05:24 AM
deathwishdave
07-23-2015 06:00 AM
briandwlee
05-13-2011 11:01 AM
techs4design
03-31-2011 06:29 PM
MTV2002
07-30-2006 01:31 PM
Quick Reply: MMI Help!!! Adding iTunes Playlists to Jukebox
