Old 07-25-2016, 01:03 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi Q5 or Q7 Interior Guides
Print Wikipost
MMI Entertainment Options Summarized
Old 09-02-2015, 04:01 AM
  #371
DB22's Avatar
The best audio in a C7 is from a DVD where the source is derived from the original mix at 48K 20/24 bit (or sometimes a render from 96K masters).
Go listen in your driveway or VIM via VCDS for "Bands on the Run".
Old 09-02-2015, 04:09 AM
  #372
subterFUSE's Avatar
Good point. I forgot about DVD audio.
Old 09-02-2015, 05:36 AM
  #373
DB22's Avatar
Just to clarify, the A6 will not play DVD A but it will play audio from a DVD.
OK, I bet that is more of a confusion than a clarification.
Old 09-02-2015, 11:06 AM
  #374
subterFUSE's Avatar
Well then.... So now the question is which audio formats are supported via DVD?
On pre-facelift C7 the Jukebox and SD Card do not support any lossless formats, not even WAV. So what does the DVD drive support? If no lossless formats are supported, then we're back at standard audio CD being the top-quality option.
Old 09-02-2015, 12:35 PM
  #375
DB22's Avatar
PCM from a DVD at 48 kHz or 96 kHz sampling rate, 16 bit or 24 bit Linear PCM, 2 to 6 channels, up to 6,144 kbit/s is still the best that you can get, but I'm not sure if our DVD codecs can handle it.
My Acura plays DVDA discs at discreet 96khz at 5.1 channels, it sound very good but the system is a dead format and even Acura does not support it anymore.
Old 09-03-2015, 04:57 AM
  #376
Fithian's Avatar
My 2016 A6 with B&O plays the sample DVD-Audio from B&O. I can record these if I need to. Quality is phenomenal.
I need a lightning cable for my 2013 S5 and daughter's VW Jetta Sport, both with MMI. I understand the L cable is the one to get. Is that correct?
Old 09-03-2015, 05:15 AM
  #377
DB22's Avatar
[QUOTE=Fithian;24721008]My 2016 A6 with B&O plays the sample DVD-Audio from B&O. I can record these if I need to. Quality is phenomenal.
QUOTE]
Do you mean that the B&O will playback the DVD-A format or audio from a DVD?
Old 09-03-2015, 05:46 AM
  #378
snagitseven's Avatar
The 4F0 051 510-L appears to be the latest AMI Lightning cable.
Correction: 4F0 051 510 AL
Old 09-03-2015, 06:02 AM
  #379
subterFUSE's Avatar
Is that the Yellow grommet?
Old 09-03-2015, 06:37 AM
  #380
Yes. Actually, the correct part number is: 4F0 051 510 AL
I believe the AL replaces the short-lived AC cable, at least for MMI Nav Plus.
Quick Reply: MMI Entertainment Options Summarized
