MMI Software question
krautstyle541 (09-23-2021)
#22
The engineering menu is different from the hidden green menu.
I don't know if this helps, I have noticed that if you restart MMI (Menu + Car + Top Right) and then immediately after restart try to load the green menu (Menu + Car), it will load the engineering menu instead but then shows the message: "Not yet initialized" and then closes immediately.
Later when I try to use the same key combo it loads the green menu instead.
#23
I don't know if this helps, I have noticed that if you restart MMI (Menu + Car + Top Right) and then immediately after restart trying to load the green menu (Menu + Car), it will load the engineering menu instead but then shows the message: "Not yet initialized" and then closes immediately.
#24
You two need to grow a pair. No one said is risk free, but do your homework, don't take shortcuts and the risk becomes far more manageable. When I was trying to get the update done, if the CD was available i would have taken that approach rather than argue with the dealer for 6 month.
Case in point, I grafted Audi connect to my car which was far more complicated than a CD update.
And it also looks like someone has successfully done this already on one of the other forums.
#26
Thanks for the info. I did try your suggestion when I got home. After playing with different combos for a while, it turns out, at least on the version that I have, v487, that in order to open the Engineering update menu, you have to be on the regular software update menu and then use the CAR+BACK buttons. Once I tried the buttons there, it popped up immediately.
I plan to attempt the update process again this weekend.
Thanks, again!
#27
Do you have a link to the forum posting that you mentioned? I'd love to use it as a reference if I need it.
Thanks
#29
I bounce back and forth between forums. If it's not, axe it:
[VIDEO] Updating the MMI in a US A7 (C7) by Yourself
Posting my findings there currently.
