NAV/maps questions
NAV/maps questions
I've had the car about 2 weeks now.
1. I updated the maps through the MMI online, and it was about 250 MB.
I downloaded the latest maps through AC online and it was about 1.3 GB. I haven't used it yet, but probably will. Why the difference?
2. When my NAV is on auto, it's showing the night image even though it's sunny-- it's darker. When I change it to Day, it corrects itself and becomes brighter, until I change it back to Auto. Is there another setting somewhere I'm missing? Is there a sensor or time issue? It's an issue whether or not it's on Google maps or the standard one.
Thanks
There was a dropdown in one of the settings in the MMI that listed an update for AZ that I did, which ran ~250 MB. When I logged into AudiConnect, there's a 1.3 GB download that I got using their flash downloader that I transferred to an SD card, but haven't used yet.
I'm wondering why the size difference.
Your map shouldn't be going to nite mode in broad daylight. Has it been this way since you had the car? If the things 1st Time Audi mentioned didn't fix it, I'd say just play around with it some more. Sounds like a setting issue. Turn your lights to the Off position and see if it still happens. Try it out in the afternoon, too, because sometimes mine seems time dependent, not just brightness. The map will also dim when you press the cornering or rear fog lights buttons.
