Nav Update
Nav Update
Hi
I am a proud new owner of a 2013 A6.
I purchased a Nav 2014 / 2015 update from ebay. Part number 8RO051884CAT1000-22286. This is a SD card. It was an impulse buy and fairly cheap. I am trying to do some research before I try to upgrade.
Did I waste my money? Do I need a pin number from Audi before I can install this?
Thanks
Thanks
Hi
Thanks
Thanks
With the next A6 design, Audi will probably use the new MMI system as found in the A3/S3 that will supposedly allow the owner to download MMI and Nav updates via LTE.
I didn't realize the 2016 C7 had the capability of downloading nav and MMI updates. I thought that came with the new MMI that has DIS map, display configuration, etc. as found in the A3/S3.
It can download and updates wirelessly, but since it is so slow, I'm worried how long it might take in the future.
I just updated my 2016 S6 by downloading nav update to a memory card from Audi connect then doing the actual nav update from the card. It did not take that long and I believe the update probably completed even after I turned the car off.
Blah, doesn't look like I can download update NAV for a 2013.
I did some research and there is a diy way to activate the map. I don't consider it stealing since I purchased the map. I think there is a problem with the vin number in the MMI afterwards. I need to do more research.
