pump air to tire in low temperature?
Old 02-03-2014, 01:59 PM
q5q7's Avatar
Default pump air to tire in low temperature?
my tire pressure reads 28 psi for all 4 tires in 20degrees, It may translate to 34 degrees in the summer.
question: do you adjust the amount of air in the tire as temperature changes to retain a constant reading(say 35F/32R as manual suggested) ?
Old 02-03-2014, 02:27 PM
Banned
Mike_L's Avatar
You should be raising your pressure to keep the recommended pressure year round.
Old 02-03-2014, 02:40 PM
q5q7's Avatar
got it thanks Mike.
Old 02-03-2014, 03:04 PM
newmoon's Avatar
Yes I do adjust to keep the pressures constant when there are big temperature changes. When they are 3 psi low, you can already start to feel the steering getting heavy and the ride feels sloppy.
Old 02-03-2014, 04:07 PM
keithl's Avatar
I check my tires every 1-2 weeks and as temp drops I increase so that cold pressure is where I want it. During peak of winter I may go up and extra 1-2 PSI cold since my garage is warmer and when the car is sitting outside at work all day on a cold day I like to compensate for that drop. I don't mind tires being being over rather than under my desired pressures.
garberfc
16
11-23-2018 12:07 PM
C6Silver
Q7 MK 1 Discussion
10-09-2013 08:35 PM
CT Audi Fan
9
02-09-2006 01:43 PM
Loreon
06-29-1999 06:33 PM
Quick Reply: pump air to tire in low temperature?
