Rain sensing wipers
Rain sensing wipers
I have never had rain sensing wipers before so not sure how they are supposed to work. Only have had car for 3 weeks now but have noticed when it has rained the wipers don't come on on their own (I have the wiper stalk in the position one up from off). Is this as designed where you need to start them before the intermittent setting does its thing automatically?
I thought the stalk adjustment was for timing delay.
so the wiper come on automatically if it detects enough rain? small bar means more sensitive?
assume they needs to be turned off to not come on in a car wash?
The sensitivity adjustment will affect how often/how fast it operates but will also affect how likely it is to start operating. Try moving to a middle position and then adjust as needed.
Generally you do not need to adjust it very often.
Yes, make sure it is off when going through a car wash otherwise the wipers could get caught up or damaged by the cloth.
Off topic but I would never take my through a car wash that had anything touch my car's paint except water and soap. Touchless only unless you want small scratches and lots of swirls from those brushes and "slappers" full of dirt from the last fifty cars that went through before yours. Same goes for any car wash where they have someone dry your car with dirty, scratchy towels.
I agree with you. I've been doing 2 bucket rinse-less wash. Got some parts of the car wrapped with xpel and then did opti-coat over it all but am in no hurry to have the car wash guys scratch it all up. Being in NY winter will be a problem but have done some research on hand car washes in the area I will try out.
Rain Sensing
Just be aware that the rain sensing feature can be turned off in the MMI.
Sensitivity replaces timing on cars with rain sensor wipers. The more you move the adjustment to the right the more sensitive it gets. Sometimes when it first starts raining the wipers need to realise it is raining by you doing a single wipe, easy to do if you just move the sensitivity control up and back down, after that it can detect the rain properly and wipe as required. I find leaving mine at the least sensitive setting is fine
