Red iPod Cable Information
#111
Not so sure about that. I stream live stuff frequently over both blue and red AMI cables. I've only had the red cable for a few weeks. This is on an A8, but I'm pretty certain MMI isn't that different between the A6 and A8 lines. You may want to ensure that you have 0566 firmware or later.
A
A
#112
MMI software 0566
IOS 6.1.2
#113
Good news. Looks like I will be purchasing a red cable soon and begging my dealer for the 0609 software upgrade.
#114
Thanks.
#115
Their are several threads discussing software updates from a dealer. Normally, I would suggest a forum search but since the search function is erratic right now I'll point you to here:
https://www.audiworld.com/forums/sho....php?t=2843827
Bottom line, you have at least MMI 0566 and there doesn't seem to be much difference anyone can confirm with 0609 except the removal of engine off with driver door opening and auto e-brake applied in park when engine is turned off. These two can be removed with a TSB by the dealer at the owner's request but the TSB doesn't update to a new software version.
#116
Depending on when you got your '13 A6 you have MMI software 0566 or 0609 (the latest).
#117
There is also an newer sw 0566 v.2 that had a preview view of street view. Maybe that one had this brake engaged update
#119
PO118
I have a 2012 Q5 and the software version is hundred versions from the "supported versions". Bonkers! I have software version PO118. I was about to buy the red cable but now know the cable may not be supported... unless others tried it? Perhaps if I take it in with the red cable and complain it does not read my Ipod 4gen touch, they would update. Still under manufacture warranty + certified warranty.
ltooz_a6_a8_q7
14
04-12-2024 12:11 PM
xkahn
02-08-2018 10:43 AM
Audi Other FS: 2007 Audi RS4 black/black CCW
ilikeit
01-09-2016 09:24 AM
ltooz_a6_a8_q7
Q5/SQ5 MKI (8R) Discussion
12
11-29-2015 07:21 PM
