Replacing Goodyear Eagle LS2 tires on NEW A6?
#11
I suggest 18s for more tire sidewall for ride comfort improvement and protecting the rims from pothole damage. They do a good job on vetting the quality of what they carry, so if you correctly enter the car description and note your original tire size, they will take you through the choices. Pressure cast is superior to gravity cast in the wheel descriptions and look for lighter weight...see what you like. You don't need to do the winter set now, but don't forget the TPMS if/when you eventually order.
#12
So I need to order my tires with TPMS? And I assumed that a local Tirerack installer would install them properly? Should I ask the installer to make sure?
#14
To replace your current tires, all you need are the tires in the proper size for your original wheels. The original TPMS will stay on the original wheel, while the new tire is installed on those wheels. For this installer, call ahead and be sure they have a "Hunter Road Force" balancing machine. This provides a more accurate balance for better results.
#15
thanks, really appreciate the responses. i should be all set with tires. wheels seem a little more troubling. not many reviews out there on wheels.
i really like to know and see what other A6 owners are installing for wheels.
my A6 color is Havana black, what should be the proper wheel color? black, graphite, silver, etc.?
#17
#19
Those are no longer available, but who knows, might come back. They did just fine this past winter with Blizzak WS80 wrapped around them....turned the A6 into a winter tank...went through and confidently stopped and turned in all conditions! Funny part is that when the OE wheels went back on, my wife commented she liked the Anzio appearance better!
