Rolling back on hill
My parking spot at work is in the basement. There is a gate in the middle of the up hill. I have to stop and flash my card and wait for the gate to be open and then drive out. At the gate, when I released the breaks my car would roll back. I was very surprised. It wasn't really sharp hill at all.
Previously I had Japanese cars and I drove that ramp many times and I never had this. And I thought automatic shift doesn't do that. Am I wrong?
AFAIK, there is supposed to be a hill holding feature on the A6 that will momentarily hold the car while you move your foot from the brake to the accelerator. In your case, the obvious possibilities are:
- the hill isn't steep enough to engage that feature
- you're wanting it to hold too long and it's letting go
- or there is a failure and it should be checked by the dealer.
Will be interested to learn what you determine is the issue.
The 2.0T may have a very loose torque converter. Its a very small turbo motor, so it needs to be able to get the revs up quickly so it doesn't trip over itself. If they give it a higher stall speed, the converter will allow the motor to spin up quickly and get into boost. Unfortunately, a higher stall means a looser converter, so it may not hold the car in place on an incline.
Also, it appears that the OP has the CVT which has a multiplate clutch and not a torque converter, so it does not constantly apply drive creep. If the hill hold feature is not holding the car, there may be a split second delay while the clutch engages, during which the car may roll back.
In these cases, it would be a good idea to engage the electronic parking brake. It will hold the car and release automatically once you press the gas pedal.
My 14 Pretige has hill hold, even as I coast toward my driveway waiting of the garage to close the hill is slight, but I feel the hold kick in and stop the car and when I hit the gas I feel the brakes let go.
This is correct.
