Spark plug replacement DIY
#21
If your driver is a little longer, you can take the cover off where the air filter sits (perpendicular to the car). That'd give you more room, I believe its just two plastic screws holding it in
See here for reference
https://cimg1.ibsrv.net/cimg/www.aud...-10-150833.jpg
On the driver side, once you move the coolant bottle, it was pretty easy. Just need to maneuver the coolant bottle around a bit. The only "issue" i had was leaking coolant out of one of the disconnected hoses, I grabbed a helper and had them hold it upright so it wouldn't leak.
#22
not sure if this will help but just did my plugs last weekend. Car idles much smoother but getting the coil packs off was ridiculously difficult. I did find that using a 1" wide strap looped under the bottom of the connector on the pack allowed me the grip needed to pull them out. Just be careful when pulling as when they let go you don't want them flying out of the engine compartment.
#23
#24
Next day after replacing the plugs.. holy sh** the car idles so much better and the throttle response is way better. I would have replaced mine at 45K instead had I know the power loss I was getting.
#25
Coolant Level Sensor Connector
Bill:
Thanks for the post. You've inspired me to give it a try. Hardest part to me seems to be figuring out how to disconnect the coolant level sensor connector without breaking it so the tank can move over a bit more. What's/where's the magic push or pull thingy that releases the connector?
#28
I am wondering if changing the plugs would help with this slight vibration/pulsation issue?
