2012 A6 Coolant Temperature Too High!
Old 05-13-2014, 04:41 PM
casmith's Avatar
Default 2012 A6 Coolant Temperature Too High!
Hi
I have a 2012 A6 Prestige with 62k on it. After about 20 minutes of driving or less depending on outside temp and ac usage, the car over heats and I receive "coolant temperature too high" as a message. I of course turn the car off and let it sit and cool down. I took the car to get serviced and was told there was an air pocket in the coolant system which they say was low. I drove the car for another 20 minutes or less and received the same issue. Has anyone ever had this issue before? I don't see any leaks or signs of water, the engine doesn't even seem to be really hot. I'm wondering if it may be a sensor error, or is it really that the water pump and thermostat need changed. Any help would be greatly appreciated. Thanks so much....
Old 05-13-2014, 05:00 PM
mjfloyd1's Avatar
Lots of thermostat failures. Some water pump failures as well.
Old 05-13-2014, 05:12 PM
jcman's Avatar
Originally Posted by casmith
Hi
This is the C5 forum have you tried the C6 forums?, although I do agree that CTS sensors do fail.
Old 05-13-2014, 05:21 PM
tenspeed's Avatar
The 2012 A6 is a C7 platform. There have been several reported thermostat failures with the 3.0L TFSI engine. Some shops replace the water pump too.
https://www.audiworld.com/forums/sho....php?t=2858298
Old 05-13-2014, 05:59 PM
casmith's Avatar
Thank you so much, I appreciate it.
Old 05-13-2014, 06:01 PM
casmith's Avatar
Thank you so much, I am VERY new to this. I'm just desperate for help. I appreciate your assistance.
Old 05-14-2014, 04:51 PM
jcman's Avatar
Very informative indeed, but this is the C5 forum.
Old 05-15-2014, 03:55 AM
SloopJohnB@mac.com's Avatar
Agreed. It's more likely a thermostat failed closed. If I were king all thermostats would fail open…at least you could drive the car. Unsane audi engineers.
Old 05-15-2014, 03:56 AM
Probably end up pulling the w/p anyway to get to the thermostat..investigate w/p at that time.
Old 05-16-2014, 09:44 AM
Zaphodb17's Avatar
Make sure the secondary coolant fan is working, too. Mine did this only when I turned the A/C on, turns out the electric fan had croaked.
Quick Reply: 2012 A6 Coolant Temperature Too High!
