Sport steering wheel with heating feature
Old 01-18-2015, 12:53 PM
  #11
snagitseven's Avatar
I believe I've read that there would also be some code changing necessary to make it work.
Old 01-22-2015, 02:29 PM
  #12
fEArmE's Avatar
Installed the steering wheel and it works perfectly. Now I have heat and paddle shifter. The best $200 spent.
Update: Increased the default temperature of 28°C to 32°C and I can definitely feel the difference. The steering wheel will heat until it reaches 33°C then stop. When temperature drops to 31°C, current will kick in and heat up steering to 33°C.
Old 01-23-2015, 07:24 AM
  #13
2008A6's Avatar
Great to hear! I have a non-sport wheel and would love to snag this sport wheel, but the different airbag makes it cost-prohibitive
Though i dont have heated steering, so i wonder if the heat button will just function like my current programmable button?
Old 01-23-2015, 11:50 AM
  #14
Seattlite_A6C7's Avatar
I'm curious about the same thing...I have a sport steering wheel without heat, but wondering if it'd be plug and play if I installed this sport wheel with heating. In other words, does the power supply that allows the * button to work also power the heating element in the heated sport wheel? If so, I'm buying for sure, $200 would be well worth it.
Old 01-23-2015, 01:44 PM
  #15
fEArmE's Avatar
I am pretty sure the heat button will not function like the * button, which is the voice guidance on/off.
The * button does not require additional power supply. The heating feature has an additional connector on the steering wheel which you can plug into the steering column. But I am not sure if your car has that additional power supply connector since you do not have heated steering wheel to begin with. You can remove the airbag and take a look first. It only take 10 minutes.
Update: This is what you need. The bottom left translucent connector is the power supply to heated steering wheel.
Old 02-14-2016, 10:38 AM
  #16
tenspeed's Avatar
Would you happen to have the part number of this clock spring? Thanks
Old 02-14-2016, 01:10 PM
  #17
fEArmE's Avatar
Unfortunately, I dont.
kinderutz
Audi 100 / A6 (C4 Platform)
01-14-2009 06:31 AM
kinderutz
01-11-2009 09:41 AM
kinderutz
01-11-2009 09:40 AM
kinderutz
Audi Original "S" Cars
01-11-2009 09:38 AM
CapitalAudi
05-31-2003 08:15 PM
Quick Reply: Sport steering wheel with heating feature
