Parking Assist stopped working
Old 11-16-2022, 04:18 AM
BSP62's Avatar
Default Parking Assist stopped working
Hi, I have an A6 Avant C7 2014 plate
Last week the rear park assist stopped working. When I put the car in reverse I get a constant beep but there is no display from the rear. When I put it in 1st it is fine & as I approached an object you could see the waves on the display & the pitch changed the closer I got as you would expect.
I checked around on Google & saw a post advising I cleaned the sensors with WD40 which I did but this made no difference. A few days later the front sensors also stopped working & now when I press the park assist button I get a constant beep and the display shows the park assist symbol with a line through it at both the front & rear of the display.
The car was in my local garage yesterday for a service so I asked them to check it out on their diagnostic software which came up with the following faults
B107614 Left rear sensor parking aid Open circuit/ground short
B107631 Left rear sensor parking aid No signal
B107604 Left rear sensor parking aid Component defective
B107A14 Power supply voltage for parking aid sensors Open circuit/ground short
The diagnostics also through up a few other faults on the tank flap locking motor and electronic parking brake, I have had periodic issues with both but switching the brake on and off always clears it and the fuel flap sticking hasnt been an issue for months now.
The garage did a reset & tested again and every fault with the exception of B107A14 Power supply voltage for parking aid sensors Open circuit/ground short have cleared.
As it was only booked in for a service the garage said they did not have time to look into it so I am still without park assist
Another article I have seen suggested checking the fuses which I have done. according to the manual the fuse for the park assist are located in the side panel in the boot and it lists the following
Fuse carrier Green fuse number 10
Fuse carrier Black fuse number 12
Fuse carrier Brown fuse number 11
When I checked there is no fuse in either green 10 or brown 11 and the fuse in black 12 is fine
Should there be fuses in all the locations listed in the hand book or just one of them
If the fuse is OK & all the other faults recorded have cleared what is likely to be causing the malfunction
Any help greatly appreciated as I am a complete novice
Mike Janes
A4 (B9 Platform) Discussion
11
01-18-2023 03:25 AM
minime263
A4 (B8 Platform) Discussion
02-12-2020 01:30 AM
Richard Hardwick
01-16-2020 09:07 PM
svetlin_borisov@yahoo.com
09-04-2018 06:16 PM
stockyarda4
08-31-2003 11:17 AM
Quick Reply: Parking Assist stopped working
