Subwoofer upgrade complete - and it rocks!
#262
Had to read all the thread in here.
Still sticking to the subwoofer i mentioned above.
If anyone can give me an advice with the amp please.
Will this one JBL GTO 751EZ ONE (1) CHANNEL MONO CAR SYSTEM POWER AMPLIFIER be bompatible with this sub: JL Audio 10w0v3-4 10 Inch 25cm 300 Watts 4 ohm Car Sub Subwoofer
Thank you for any help
#266
Rear Deck Stabilization Best Practice?
As is well documented, there's vibration in the rear deck at mid-high levels of bass because the wafer-thin subwoofer is there (and I'm guessing sound engineers aren't responsible for interior panels and didn't care).
So, whether keeping the existing sub or adding a new one, what's the west way to eliminate the rattle? Thanks!
#267
#269
You cut the tiles to the shape(ish) you want. Stick them on the metal. Use a roller or your hand to make sure there is good adhesion. I tried to google some videos on you tube. There are many, just not for the a/s6 c7. You can usually go to an audio shop and for a few bucks they will do it for you.
#270
You need to add a CLD product to the metal surfaces of the rear deck.
CLD = Constrained Layer Dampener
Some common products are Dynamat, Hushmat, Stinger Roadkill, Focal BAM.
The CLD prevents metal surfaces from resonating.
After that, you'll need some closed cell foam to provide a buffer layer between the rear deck and the trim panel. That way if the panel vibrates it does not hit against the hard surface and cause buzzing.
