i Phone 5s functions compatibility
Audi A6 Le Mans 2009 2.0TDI Sline with MMI, is it possible to access my music files via bluetooth, I can connect the phone for phone facility but not access my music, is there any way I can dothat without using the aux lead?
C6 platform did not support Bluetooth streaming of audio. You will need to retrofit AMI (unless you already have it) or some other audio device compatible with MMI to get access to the music on your phone. Assuming you have a facelift car might be easiest to put your music on to an SD card and use the the slots in the base of the multimedia unit in the glovebox
I am able to access with my Iphone 5s. Pandora / Spotify / ESPN SPortscenter / downloaded music or whatever i want to play. Check your phone settings on your MMI... I seem to recall a Phone and/or Music setting. Good Luck
musiclover
06-21-2010 06:24 AM
allroad'Ed now
Audi allroad
05-22-2005 06:32 AM
shimmers
05-05-2005 01:18 PM
