Too much noise from the road enters cabin?
#51
I'll def check that out later. I would think the dealer would set them at the normal level but who knows.
#52
Too much noise enters cabin
I just got thru reading all 5 pages regarding road noise .I had a 2010 A6 Avant 3.0 t prestige that came with Dunlap tires, They where so noise that I changed them too Michelin sport tires which improved things to a acceptabel noise level.
And I was reading about all the problem folks had with the Peralli tires.
I just took delivery of my new 2014 A6 Prestige with Peralli tires. After reading all the problems I checked the car yes they are Peralli but there Cinturato P7 255/40 /R19 100H M&S.
After driving the 2010 for 4 Years the new one was a pleasure to drive without any notisable road noise.
Hans
Hans
#53
BTW, be sure to check the pressures when the tires are cold.
#54
Had a tire blow on me recently so just decided to replace all 4 since the P-Zero's only had a couple thousand miles of tread left on them. I went with the 255/35/20 Pilot Sport A/S 3s, and unfortunately not too happy with them. There is still plenty of road noise, almost seems like more especially on the smoother surfaces. I'm also getting some swerving at higher speeds I never had before and the ride seems too be less forgiving regarding small bumps on the road.
Anybody else disappointed with the A/S 3s?
#55
So I checked the tire pressures on the A/S 3s and they were actually set at the normal recommended PSIs from the manual. I also checked the sound level on a pretty smooth stretch of freeway at 75 mph and it was averaging 82db, which is comparable to the Pirellis. Something doesn't seem right. Michelin has a 30 day return policy I may need to check out.
#56
just so we are comparing apples to apples here - at least as much as you can without a controlled experiment. Are folks using the DB Meters testing while driving 70 mph on concrete or asphalt. There will always be a difference between the two surfaces when it comes to tire noise.
I don't have that many asphalt roads in my area that allow highway speeds, travel often to AZ and thats all they have - so I think we need to start caveating our results with the road surface.
#58
So I downloaded an SPL meter app for my iPhone, and today I tested the road noise on my drive home.
I was averaging 65-70 mph on a new, fresh asphalt highway. This road was poured not even 12 months ago.
The average noise level was 80 dB, with peaks of 95 dB when driving over less smooth sections.
This is very loud, needless to say. 90+ dB noise levels can and will cause hearing damage over the long term.
I'm going to get rid of my Pirelli tires soon, and get some Michelin PSS. Hopefully this will make some improvement. Will report back when I do.
Long overdue follow-up on this.
We have completed my new stereo system upgrade and one of the areas of focus was improved sound dampening. As stated before, when driving on the highway @ 70mph the average road noise level was 80 dB.
We took the interior apart, and removed the seats and carpet. Focal BAM dampening was added to all metal surfaces we could find. Careful attention was made to lift all OEM wiring and put the dampening underneath it, so that the wired would still be serviceable.
Seats Out:
Interior removed:
Focal BAM dampening:
On top of the Focal BAM we used 2 layers of Luxury Liner Pro, which is a combo layer of mass-loaded vinyl & closed-cell foam. The MLV is a soundproofing layer, while the foam serves as a decoupler.
The rear deck also got treated. Both sides.
Door panels, too. Focal BAM and Luxury Liner Pro, cut to fit each door panel.
The doors are as solid as a bank vault now.
Net result?
On the highway at 80mph, using the same dB meter, the average is now 65dB. Previously was 80dB+. There is still some noise from the tires depending on how smooth the road surface is. Unfortunately, that kind of noise is very tough to stop. But overall, a 15dB reduction is a huge improvement.
Now I just need to start the tuning process for the audio. New stereo build log coming soon, too.
Edit: I just re-read my old post. My old testing was at 70mph on a freshly poured asphalt road. Averaging 80+ dB with peaks above 90dB.
With the new sound dampening I tested at 80mph, so I was going even faster. Theoretically, I would expect the old setup to be louder at 80 mph than 70mph. And at 70 it was pushing above 80dB. I'm now averaging 65dB @ 80 mph on smooth asphalt. That's a very dramatic difference.
#60
Impressive indeed
I'd be interested in knowing the fragility level of this interior removal. Gutted the C4S6 couple times in the past...
