USB Connection on 2016 A6
Old 01-14-2017, 05:41 AM
Fithian's Avatar
Default USB Connection on 2016 A6
There has been a problem with the USB connectors not supplying power to the connected devices. This happens all of the time, but if the connection is reconnected, it sometimes allows power. A similar problem occurs with the 12v outlets front and rear. It is at the dealer now, and they don't have a clue. We were given an A3 TDI as a loaner. I wondered what they were going to do with all of those diesels ;-)
Old 01-14-2017, 06:05 AM
Tech Guru
4Driver4's Avatar
What are you plugging in? Sometimes devices are picky about the amperage, and it if is too low they won't take a charge.
Old 01-16-2017, 07:43 AM
Fithian's Avatar
I have tried it with an iPhone 5S, iPhone 6S+, iPhone 7+, iPad Air 2, iPad Pro, using 5 different usb-lightning cables.
Old 01-16-2017, 03:53 PM
joedaman88's Avatar
Just curious, are the cables you are using the original Apple cables? If they are not, are they MFi certified? I had similar issues on another car when I bought some cheap cables from Marshall's once.
Old 01-20-2017, 08:57 AM
Fithian's Avatar
I used 6 different cables. some MFI, others not. Dealer replaced the USB module in the dash and everything works well now.
ptr727
06-26-2023 01:08 AM
reedster25
03-14-2011 09:00 AM
AUOOOO
06-21-2006 10:50 AM
Ken-Arild Kristiansen
07-17-2002 03:25 PM
hillman
07-26-2001 12:04 PM
Quick Reply: USB Connection on 2016 A6
